Precision Screw Extractor Set
  • Precision Screw Extractor Set
$19.99
$19.99
ご希望の商品が再入荷しましたらお知らせします。
Free shipping on all orders over $100.00 or containing a Pro Tech Toolkit!
当社のショップを閲覧する
Ever fixed something? That’s Genius.
Share your repair story with #ImAGenius
We Are All Geniuses
製品詳細
概要
概要
Extract tough stripped screws without damaging the device.
  • Safely remove stripped screws and replace the age-old practice of coating the screw-riddled device with wax and feathers and hurling it into the sun.
  • We know how annoying stripped screws can be. Before you resort to the rotary tool or super glue, give these little guys a try.
  • Hardened bits with 4 sharp points for gripping what's left of the screwhead safely.
  • Extractor tips are double-sided and reversible:
    • 3 drivers have the same size bits on each end, and 1 driver has different sizes on each end—a total of 5 different bits.
  • Anodized machined aluminum handles with swivel tops and pocket clips.
  • Made in USA.
メモ
This tool requires some mechanical aptitude and careful feel. If you stripped a screw while carefully using the correct type of driver the first time, it is possible you will not be successful with this tool. Screws that are cross-threaded, jammed, or glued in place will be very difficult to remove with any tool. Our Screw Extracting Pliers are easier to use, but will not grip recessed screws.
顧客レビュー
この商品を購入された方は次の商品も購入されています。
