Phillips #2 Screwdriver
  • Phillips #2 Screwdriver
$2.99
$2.99
ご希望の商品が再入荷しましたらお知らせします。
Free shipping on all orders over $100.00 or containing a Pro Tech Toolkit!
当社のショップを閲覧する
製品詳細
概要
概要
Unless you require a #2 Phillips driver for a deeply recessed screw, we recommend purchasing our 6-in-1-Screwdriver, which includes a Phillips #2 driver.
修理にまつわるストーリー
ユーザのアバター
問題
Computer was constantly running fans with little to no actual load. Upon closer investigation the computer was getting as high as 90 degrees Celsius when doing moderately demanding tasks.
修理
Opened the case and saw a bunch of dust everywhere. After the dust was removed the real problem revealed itself. . . .
ユーザのアバター
問題
Replaced built in optical drive with 250GB SSD drive. System was running really slow.
修理
It went well. Followed instructions and was pretty straight forward. Ran into a few hurdles....The screws can easily fall down into the case, which was very annoying. There is also a cable that has a very sensitive . . .
ユーザのアバター
問題
No facilities available in Australia, apparently.
修理
Quite ok. Thanx for online instructions.
アドバイス
Spludger
invaluable.l
ユーザのアバター
問題
My iMac 27 Inch i5 always frozen...
修理
Very well, I managed to happily. It 'just install "Fan control" fan set at maximum speed and the problem is solved!. For an excess of zeal, oh then apart my iMac 27 to carry out additional cleaning.
アドバイス
No, nothing special
ユーザのアバター
問題
The power supply of my Imac was broken
修理
My iMac is a 24" aluminum one, unfortunately there was no official guide on the website. However, there was a guide for changing the power supply in a 20" iMac, so I used that. There was also a video of the friendly lady, who made the repair look very easy. I al . . .
もっと表示する
