P6 Pentalobe Screwdriver 2009 15" MacBook Pro Battery
  • P6 Pentalobe Screwdriver 2009 15" MacBook Pro Battery
  • P6 Pentalobe Screwdriver 2009 15" MacBook Pro Battery / iFixit - Made in Germany
  • P6 Pentalobe Screwdriver 2009 15" MacBook Pro Battery / Moody - Made in USA
$8.99
$8.99
ご希望の商品が再入荷しましたらお知らせします。
製品詳細
概要
概要
Use this precision P6 pentalobe screwdriver to service your Mid 2009 MacBook Pro 15" Unibody laptop battery. This particular size of pentalobe screw was used by Apple to secure the battery to the device. The P6 driver is compatible with the same screws as Apple specialty tool 922-9101.
The iFixit P6 pentalobe screwdriver features a knurled grip and rubberized, ergonomic handle with swivel top. Made in Germany with uncompromising quality in manufacturing, this precision P6 pentalobe screwdriver is the last driver you'll ever need to buy. And to back that up, it's covered by iFixit's Lifetime Warranty.
Check the product option dropdown for the ESD-safe screwdriver made by Moody.
Please note: This is NOT the driver to open models of Retina Display MacBook Pro or MacBook Air. That driver can be found here: P5 Pentalobe Screwdriver Retina MacBook Pro and Air.
修理にまつわるストーリー
問題
I tried to replace the battery for my macbook pro of model mid 2009. The 3 screws that fixed the battery were five-star shape. I could not get them off using the screwdrivers came with the battery.
修理
I bought two set of precision screwdrivers from walmart, containing 30-60 pieces. But none of them work . . .
問題
I purchased a battery for a mid2009 MacBookPro 15" screen . tools were included. However, wrong size. iFixit stocked the size it required.
修理
Smooth
アドバイス
The on line store where I purchased the battery from reimbursed me for the cost of the entire iFixit purchase; including S&H!
問題
The IMAC PRO 2009 model Battery was no longer charging though it was still working from the power cord .
I looked at all options including replacing the Mac
修理
After watching the video tips.. I remembered what i had to do.
It took me less than 10 minutes to change it ..half of that was chat ting to my . . .
問題
I needed to repair my trackpad, looking at some tutorial online to see if there is a way of fixing it, so I started unscrewing the bottom open up the laptop, then the trackpad is under the battery so needed to remove the battery 1st
Then looking at the battery I noticed it wasnt a regular shape and . . .
問題
The old battery didn't have much life left in it, but that was actually the smaller problem. The battery had gotten to the point where it had swollen so much that it was pushing up on the bottom of the track pad made clicking impossible. I had to enable some of the multi-touch features just to be ab . . .
問題
Black screen when turning on computer.
修理
Good.
アドバイス
Just to add how approx. how much thermal paste to use.
問題
Battery was bloated after using for 5years.
修理
Excellent! instructions were clear and it was easy to replace!
アドバイス
When screwing
Anti- clockwise = unscrew.
vice versa.
問題
Battery would not charge
修理
It was pretty easy with the right tools and a guide. One screw is hidden and the guide showed where it is.
アドバイス
Doesn't take very long; be careful not to lose any of the tiny screws.
問題
battery time was down to 15 min
修理
repair was done without any problems. Took about 10 min
アドバイス
description is complete
問題
The old battery had swollen enough to push on the trackpad.
修理
The repair went exactly as advertised!
アドバイス
Because the old battery was swollen, it pushed against the bottom case panel with enough force to throw the tiny screws some distance as I loosened them! If your old battery is swollen, take care to appl . . .
もっと表示する
