P5 Pentalobe Screwdriver Retina MacBook Pro and Air
  • P5 Pentalobe Screwdriver Retina MacBook Pro and Air
  • P5 Pentalobe Screwdriver Retina MacBook Pro and Air / iFixit - Made in Germany / New
  • P5 Pentalobe Screwdriver Retina MacBook Pro and Air / Moody - Made in USA - ESD Safe / New
$11.99
$11.99
ご希望の商品が再入荷しましたらお知らせします。
製品詳細
概要
概要
Use this precision P5 pentalobe screwdriver to open Retina MacBook and MacBook Air laptops. The P5 driver is compatible with the 5-point star shaped pentalobe 5IPR security fasteners used on the bottom of some Apple laptops.
This P5 pentalobe screwdriver from Moody Tools is made in USA and features an ESD safe handle with a swivel top, and a double ended reversible pentalobe tip.
修理にまつわるストーリー
問題
battery was dying and had "service battery" alert in notifications panel
修理
Went well except that the cord for the new battery was incrementally too short. It was able to plug in barely and on a slight angle, Hopefully this will be okay long-term; my concern is having to periodically open the assembly a . . .
問題
Needed more RAM memory to upgrade to High Sierra OS.
修理
Great.
アドバイス
Make sure you hav the correct RAM memory because there are various types.
問題
My MBP trackpad was broken. Needed the pentalobe screwdriver to open my laptop to replace the trackpad.
修理
Huge pain in the ass. On my model of macbook pro, you have to remove the batteries which are glued-in to get access to the track pad. I saw a guy on youtube use a metal scraper to do it, so I did t . . .
問題
Battery for Mac Air was dead. Ordered P5 Pentalobe Screwdriver and a battery on Ebay. Followed the directions on IFIXIT, which were excellent.
修理
Everything went without a hitch. Thank you!
アドバイス
Follow directions. Carefully unplug and reconnect battery.
問題
After five years the battery had cycled hundreds of times and was showing a need for service...
修理
The swap was quick and easy... less than 20 minutes... great repair guide and product.
アドバイス
ifixit.com should always be the first place you try.... great advice and solid products...
問題
Original Logic Board had failed
修理
Repair went without a hitch.
アドバイス
Follow the instructions!
問題
Trackpad kept drawing squares
修理
Good.
アドバイス
I used a T6 screwdriver instead of a T5 on step 10. Don't removed a metal plug that appears to be taped to the bottom underside of the trackpad.
問題
My laptop stopped being able to hold a charge. Left more than a minute unplugged the system would shutdown.
修理
Easier than I expected. Strangely only 4 screws were holding the case, either the others fell out or were left out by apple repair in the past.
Now the laptop can remain operational while un . . .
問題
My fan was making a weird noise. I didn't know if the fan motor was dying, or if some debris was the culprit. In either case, I needed to open up and have a look. Unfortunately, I didn't have the special pentalobe screwdrivers to open up my MacBook.
修理
My biggest problem was that I didn't even know whic . . .
問題
My sister accidentally dropped her Macbook Pro Retina after owning for more than 4 years. The warranty had expired a long time ago and the people at the Mac store gave an estimate of at least $700. When my family told me about this, I told them that was ridiculous and to order a new display from ifi . . .
もっと表示する
