P2 Pentalobe Screwdriver iPhone
  • P2 Pentalobe Screwdriver iPhone
  • P2 Pentalobe Screwdriver iPhone / iFixit - Made in Germany / New
  • P2 Pentalobe Screwdriver iPhone / Moody - Made in USA / New
$8.99
$8.99
ご希望の商品が再入荷しましたらお知らせします。
製品詳細
概要
概要
Use this precision P2 pentalobe screwdriver to open iPhone and Apple devices. The P2 driver is compatible with the 5-point star shaped pentalobe 5IPR security fasteners used on the bottom of iPhones. The driver is compatible with the security screws on the bottom of all models of iPhone since the iPhone 4: iPhone 4/4S, iPhone 5/5s/5c, iPhone 6/6 Plus/6s/6s Plus, iPhone SE, iPhone 7/7 Plus, and iPhone 8/8 Plus.
The iFixit P2 pentalobe screwdriver features a knurled grip and rubberized, ergonomic handle with swivel top. Made in Germany with uncompromising quality in manufacturing, this precision P2 pentalobe screwdriver is the last driver you'll ever need to buy. And to back that up, it's covered by iFixit's Lifetime Warranty.
Check the product option dropdown for the ESD-safe screwdriver made by Moody.
修理にまつわるストーリー
問題
Input via digitizer became intermittently erratic. I could scroll screen with finger above screen not touching. Pressing one area made phone act like I had pressed a different area. There was a light streak down screen. This problem was intermittent and would come and go while phone was just sit . . .
問題
Battery was draining within 2 hours and % remaining was never accurate (at 100%) and then would die.
修理
Super simple! Make sure that you have that pentalobe (?) screw driver.
アドバイス
My battery was taped in with double sided tape. And was very difficult to remove until I heated up the tape. I heated up a hot/ . . .
問題
My wife dropped her iPhone 6 and it popped the screen out and dented the corner. I used the Pentalobe #2 bit to remove bottom of the screen so I could place it back in properly.
修理
Very well.
アドバイス
NA
問題
The screen start flashing when turn the phone on. Save money buying the tools and fixing it myself, plus the experience
修理
Perfectly
アドバイス
Saw a video on you tube
問題
My iPhone 5s could not go 12 hours without needing to be charged. And this was with very minor use.
修理
The repair is a little tedious, but with patience and care, it can be done without hurting the phone.
アドバイス
The pulling part, when you pull the old battery adhesive strip off, be very slow and gentle, specia . . .
問題
A friend took his iPhone 6Plus scuba diving with a not so waterproof case.
修理
Was able to get the battery out and replace it...sadly it did not charge. The tool kit is amazing...every tool you need to make it go smoothly. I had watched a video with a 10 year old showing me how to open the case with an 1 . . .
問題
I water damaged my 6s.
修理
It went great!
アドバイス
Getting the front sensors, camera, and earpiece is definitely hard, but not too hard. Watch out for that.
問題
Back panel of iPhone was scratched, including across the area over the camera lens, making photo quality terrible
修理
Took less than a minute, super super easy
アドバイス
Note that the back panel on the iPhone 4 slides up a little to unlatch, you don't pry it off, you slide it a little. Reverse the motion to put the . . .
問題
screen cracked
修理
The repair was fairly easy- you do need a micro screwdriver (smaller than the smallest you can get at Lowes or HD- so, if you don't already have one, get one from ifixit, along with the P2 pentalobe driver. The screws are so tiny that I can't pick them up with my fingers. Must use tw . . .
問題
Cracked display
修理
Instructions were clear and accurate! Finished in 15 minutes. Delivery came in 2 days after my order...3 days earlier than expected!
アドバイス
I can see how reinstalling the display may put undue pressure on the tiny piece of glass under the home button. Be careful when snapping the assembly in . . .
もっと表示する
