Magnetic Project Mat
  • Magnetic Project Mat
$19.99
$19.99
ご希望の商品が再入荷しましたらお知らせします。
製品詳細
概要
概要
  • Simply organizes all your parts while you work on a device.
  • Dry erase surface lets you keep notes and stops mistakes.
  • Reduces reassembly time by up to 40% while preventing errors.
Designed by fixers, for fixers, the 8”x10” Magnetic Project Mat solves this repair problem. Spacious and secure, the mat will catch and hold screws as you pull them out of a device.
Great for cell phone repairs, and you can stop worrying about screw tracking and focus on the cell phone all the screws will be right where you left them. For laptops with hundreds of screws, use the whole mat as a screw guide and keep careful notes to not get lost.
The included pen is uniquely suited for the Project Mat. It’s made by Staedtler, the German pen company that makes top-of-the-line pens and pencils for artists and architects. Their Lumocolor Correctable pen doesn’t smear or wipe away like most dry erase markers, so if you brush your hand across the mat while performing a repair, the ink doesn’t scratch or smear. However, the eraser tip or a dry cloth wipes the ink away clean.
Pen wearing out? We have replacement pens.
製品ビデオ
修理にまつわるストーリー
問題
Mother's laptop was running slow. Took 15-20 minutes to boot up fully and the HDD ran at 100% during this time. So I wanted to put an SSD in to replace the mechanical drive.
修理
The repair went extremely well. Prying the top of the case apart was extremely easy with the metal spudger. I just had to run . . .
問題
The battery was inflated and the phone did not work (of course), my father thought about getting rid of it and a more expensive phone, after i asked him if he was happy with his old phone, he said he was, but had no way of changing the battery.
修理
So i went ahead and open the back of the phone, which ha . . .
問題
The iphone in question had gotten the “touch disease“ and Waikley enough replacing the screen fix the problem.
修理
The repair went great. It was very simple to follow the instructions for the disassembly and also for reassembly. I will definitely use I fix it in the future for any repair that I need . . .
問題
DEAD BATTERY-IT IS VERY INTERESTING TO DO THIS,SORT OF BREAKS UP MY DAY--IF I WORK ON THIS TO LONG, MY HANDS START TO SHAKE,
I CAN SAY ONE THING,IT HELPS ME TO CONTROL MY DEPRESSION, I HAVE ,I HAVE TO CONSENTRATE HELPS A LOT-I ALSO USE A OPTICAL GLASSES WITH LED LIGHTS ON,HELPS A LOT WILL LET . . .
問題
Batteries were so bad that phones were terrible.
修理
The phones turn on and work better; success!
アドバイス
There are SEPARATE INSTRUCTIONS for the replacement battery adhesive placement. You need those in front of you.
問題
Screen was badly cracked.
修理
Just as outlined in the instructions.
アドバイス
I reused the original Home button but still got the Touch ID error. I restored the phone from an earlier backup which fixed the error. It would have been helpful for a reminder in the instructions to backup the device first.
問題
Batteries were old and phone was running slow thanks to Apples updates to preserve battery live of old phones
修理
I was on call when I received my order so waited to do the first upgrade (I bought two iPhone batteries). Both phones have been upgraded and are working perfectly. Oddly I bought both phone . . .
問題
My girl’s screen was busted, so I decided to replace the battery as well since I was opening the phone. She’d also been complaining her phone was dying all the time, so it made sense.
修理
It’s pretty straight forward. Only one connector to deal with and the replacement battery from iFixit was a dro . . .
問題
got it to be prepared for a problem.
修理
have the tools to do the work.
アドバイス
None yet.
問題
Battery was not holding a charge for any longer than a day.
修理
Great instructions, good pictures, bad experience. It all began like the instructions indicated by removing the two external screws, placing suction cup on screen and attempting to separate the screen from the body. After numerous attempts . . .
もっと表示する
