Mac Mini Logic Board Removal Tool
  • Mac Mini Logic Board Removal Tool
ご希望の商品が再入荷しましたらお知らせします。
Mac RAM Kits
Speed up your Mac. Max out its memory.
Mac RAM Kits
Get more memory out of your Mac.
製品詳細
概要
概要
The least originally named tool we offer.
  • Simple tool pries the logic board free to allow access to the hard drive in 2010-up Mac Minis.
  • Custom iFixit version is nearly indistinguishable from Apple's official logic board removal tool.
修理にまつわるストーリー
ユーザのアバター
問題
Upgrade to SSD
修理
Found out the hard way you need to reformat the SSD before installing in the Mac mini. Otherwise it went fine.
アドバイス
Note in the guide to reformat the SSD before installing into the Mac mini
ユーザのアバター
問題
replaced HDD with SSD
修理
did not need tool to remove logic board but screen did not fit back could not use one screw
アドバイス
take risks but use good tools
ユーザのアバター
問題
One day my Mac Mini would not wake up. Leading up to this it was acting a bit unreliable.
修理
I started with first unplugging the power supply from the logic board and measuring the power supply output with a multi-meter to ensure that was not the issue. It puts out a simple 12V to the logic board so i . . .
ユーザのアバター
問題
Not a problem but an upgrade. A friend of a friend was in the market for a new computer and I convinced him to buy a Mac. A large selling point was the ability to purchase an older Mac and install a second drive and install Windows on it in the off chance he'd ever want to go back to it.
修理
"Repair" its . . .
ユーザのアバター
問題
My original 500GB hard drive was very SLOW .
修理
Super easy. Followed the instructions provided on ifixit.com, easy to follow and step by step. I was up and running within an hour. Now my Mac Mini is FAST!!
アドバイス
1. Backup to Time Machine First - restore is fast and easy.
2. Follow the instructions for a co . . .
ユーザのアバター
問題
The hard drive was to slow - change it to a SSD
修理
Followed the repair guid for harddisk installation, and the guide was really helpful.
アドバイス
Take your time and read the guid carefully. If you do, you will not go wrong
ユーザのアバター
問題
I was receiving a SMART report of imminent failure, so I replaced it with a Crucial MX300 SSD
修理
Two issues: the IR sensor was not observed. And the insertion into the drive slots was very tedious. The drive did not want to go into the two holes in the case. I also replaced the Mac mini cooling fan whi . . .
ユーザのアバター
問題
Slow mechanical hard drive - upgrade to SSD.
修理
Went smoothly.
アドバイス
Could have used some closeups on the removal of the power plug clip - you just pull it out, but it wasn't clear if it was supposed to levered up or down. Also, could have used a closeup on pulling the power connector off the logic board; it d . . .
ユーザのアバター
問題
I was tired of long boot times and slow program launches on my late 2014 Mac Mini. Even with 16 GB of RAM, the thing was pokey.
修理
The 2014 Mac Mini wasn't the most difficult Mac to work on that I've ever encountered, that honor goes to the pre-Unibody Macbook Pro. Ugh. Replacing the hard drive in the M . . .
ユーザのアバター
問題
I thought I could live with a slow spinning drive - I couldn't...
修理
The replacement went without a hitch. I was dreading some kind of hiccup along the way, but the directions were so clear and detailed, I knew what to expect at each step. So in the end, I was able to successfully replacement my stock . . .
もっと表示する
この商品を購入された方は次の商品も購入されています。
