Heavy-Duty Spudger
  • Heavy-Duty Spudger
  • 360°
360
Heavy-Duty Spudger
ご希望の商品が再入荷しましたらお知らせします。
製品詳細
概要
概要
Poke and prod like you mean it.
  • Thicker variant of the official "black stick" that Apple Certified Technicians use to repair Apple computers.
  • 6" long antistatic nylon probe with one flat end and one pointed end.
  • Flat end can be used to disconnect connectors, remove thermal paste from heat sinks, pry off components, or aid in soldering.
  • Pointed tip is handy for unlocking ZIF connectors and poking your siblings.
修理にまつわるストーリー
Ahmed Lotfy's Story Photo #738396
Ahmed Lotfy's Story Photo #738398
Ahmed Lotfy's Story Photo #738401
問題
To replace my 2639 iMac (27" late 2013) HDD with Samsung 850 PRO SSD
修理
It went smooth, thanks to iFixit guides, videos, and tools
アドバイス
Take your time to plan and prepare for it, handle the screen with extra care, no need to completely remove the left speaker if you plan to replace the HDD; only moving it a l . . .
問題
Battery would last about 4 hours from a full charge.
修理
super simple, took about 45 minutes from opening ifixit.com to turning the phone on again.
アドバイス
get good tools from ifixit first, they made all the difference.
問題
My battery was draining very fast when it got to 30% and the lighting connector was failing
修理
The repair took about 3 hours in two sessions. The last step of the lighting connector assembly replacement guide was missing the step at the end to separate the microphone cable from the plastic microphone i . . .
問題
Got my old iPhone 5 back in shape to let the kids share
修理
Piece of cake. I have repaired a couple of other phones (with iFixit's help!) so I knew what to expect.
アドバイス
Follow the online guides! They tell you how to go and what to expect. I prefer the text with pictures, but there are videos too.
問題
My 18-month-old launched her Mom's iPhone 6 in the toilet, and then started crying, haha. I was at work when it happened, but Mom said that when she pulled it out of the toilet, she tried to turn it off but wasn't able to - and then she said it got hot... really hot. So, I figured that the battery . . .
問題
WiFi would work when MacBook was cold then stop later
修理
Great! It's working again and the instructions on iFixIt's web site were perfect.
アドバイス
I, for some reason, always considered Macs untouchable for repair even though I've routinely opened and fixed Windows PCs for years. That is gone! Macs are fixable! W . . .
問題
Battery was original and only charging to 67% of original capacity. Mac Superstore wanted $150.00 for replacement. With iFixit instructions and their excellent pentalobe driver, I did the replacement in 30 minutes, for a total of $75.00 including the battery.
修理
The repair was without any issues. The iF . . .
問題
Computer refused to boot which was narrowed down after many other suggested remedies to a defective power supply. Replacing the power supply was not something that I had ever done before. But with the very detailed description given by Chris Green led me to a successful disassembly and removal of th . . .
問題
Only had one ear bud (also one speaker when using accessory on car radio).
修理
One hour had iPod apart,changed out earphone jack and battery (figured y not while I had it apart) and back together.
アドバイス
Plastic separaters weren't really used,small putty knife,metal AND plastic spudgers are a must. 00 Phillips s . . .
問題
Battery 6+years old, finally required a nonstop plug in charge. Basically, a desktop laptop. Slow and lots of beach balls was a normal function.
修理
So, I scouted this iFixit site and logged it for later. After reading many reviews. I was sold on the battery for sure. The information was spot on. Many re . . .
もっと表示する
この商品を購入された方は次の商品も購入されています。
