Heat Gun
  • Heat Gun
  • Heat Gun
Heat Gun
Heat guns may produce residual smoke when turned off the first few times and should always be used in a well-ventilated area.
$19.99
$19.99
ご希望の商品が再入荷しましたらお知らせします。
Free shipping on all orders over $100.00 or containing a Pro Tech Toolkit!
当社のショップを閲覧する
Ever fixed something? That’s Genius.
Share your repair story with #ImAGenius
We Are All Geniuses
製品詳細
概要
概要
Great for reflowing solder and melting adhesive.
  • The power of fire in the palm of your hand (except for the part where flames actually come out).
  • 1500W Heat Gun needed for many different repair processes.
  • Can be used to loosen adhesive holding device components in place, or to reflow solder to repair soldered connections.
High and Low Heat settings
  • Low setting reaches 570/300 degrees F/C.
  • High setting reaches 1112/600 degrees F/C.
The high setting can ignite things. It can also burn you. So watch out!
For the professional heat gunslinger, check out our pro model, the Hakko HJ5000.
Available for shipment only to the USA due to voltage requirements.
修理にまつわるストーリー
ユーザのアバター
Phil's Story Photo #1672575
Phil's Story Photo #1672574
Phil's Story Photo #1672573
問題
Battery died and would no longer charge or hold a charge anymore. Phone could not turn on for more than a second before shutting off.
修理
Went well except I damaged my screen getting the battery out. It now has a spot of dead pixels and green lines running down the phone.
アドバイス
Be careful when removing the old . . .
ユーザのアバター
Steven Rice's Story Photo #815542
Steven Rice's Story Photo #815544
問題
My friend dropped her phone in a parking lot.
修理
I do NOT like how this phone was constructed. I was actually maimed in the process of repairing this thing. It uses these tiny little pins to hold a metal frame onto the screen assembly. It is a horrible design. I ended up getting one of those stupid litt . . .
ユーザのアバター
問題
iPhone 8 plus screen was in very bad shape and in need of repair.
修理
Repair was as expected. Screws were small and care had to be taken not to mix them up. Make sure to have a hot air source available to loosen the glue.
アドバイス
The home button removal from the old screen goes much easier if you heat it too. One . . .
ユーザのアバター
問題
3 year old dropped it and shattered the screen
修理
again- super easy, with the right tools. I tried with cheap picks and spudger that came with the replacement screen i got from ebay...big mistake. the picks broke with half inside and half outside the case. the cheap spudger bent and was worthless. w . . .
ユーザのアバター
問題
Charging was intermittent and battery runs out fast - now all good with the replacement parts.
修理
Doing both of these at the same time is a good idea. Good parts, good repair.
アドバイス
I grabbed a BIG local business advertisement magnet from my fridge and used that up side down for all of the screws and parts. . . .
ユーザのアバター
問題
A customer's iPhone 6 was draining battery very quickly, from 55%, it would go down to 0 in around 10 minutes. I knew this was a battery problem.
修理
The screen and battery connector were very easy, but the biggest challenge has to be the iPhone 6 battery adhesive. It is so tough, and the pull tabs rip v . . .
ユーザのアバター
問題
My Galaxy Mega 2 had a shattered screen.
修理
The repair is pretty easy as long as you take your time removing the glass. It's just held together with tape so just heat it up a little around the edges and use a pick or another small tool and run it along the sides and off she comes.
アドバイス
Take your time and he . . .
ユーザのアバター
問題
RROD
修理
Repair was easy enough, just followed the directions. May want to watch a video or 2 on the X clips, pretty easy to destroy the whole motherboard if you screw this part up.
アドバイス
The whole process was pretty easy. To do the reflow, instead of initially heating the board with the heat gun, I put it in t . . .
ユーザのアバター
問題
I am just starting out in the repair business, I repair all sorts of electronics, mainly the repairs are either Mobile Devices, Laptops, Computers. IFIXIT.com has a lot of the tools that are required for repairing these devices.
修理
Repairs go a lot quicker with the right tools.
アドバイス
Make sure you have the ri . . .
ユーザのアバター
問題
I fixed it because it ha front and back screen broken.
修理
The repair went great it's fixed.
アドバイス
None i did it on my own.
もっと表示する
