Flathead 3/32" or 2.5 mm Screwdriver
  • Flathead 3/32" or 2.5 mm Screwdriver
  • Flathead 3/32" or 2.5 mm Screwdriver / iFixit - Made in Germany
  • Flathead 3/32" or 2.5 mm Screwdriver / Moody - Made in USA
$6.99
$6.99
ご希望の商品が再入荷しましたらお知らせします。
Free shipping on all orders over $100.00 or containing a Pro Tech Toolkit!
当社のショップを閲覧する
Ever fixed something? That’s Genius.
Share your repair story with #ImAGenius
We Are All Geniuses
製品詳細
概要
概要
Use this precision flathead screwdriver for electronics repair and DIY projects. It's the most basic screwdriver you'll need in your toolkit to fix laptops, small home appliances, and electronics. The small, flat screwdriver blade is also known as the "slot", "common", or "standard" screwdriver.
The iFixit flathead screwdriver features a knurled grip and rubberized, ergonomic handle with swivel top. Made in Germany with uncompromising quality in manufacturing, this precision flathead screwdriver is the last driver you'll ever need to buy. And to back that up, it's covered by iFixit's Lifetime Warranty.
Check the product option dropdown for the ESD-safe screwdriver made by Moody.
修理にまつわるストーリー
ユーザのアバター
問題
Wifi, Bluetooth and GPS weren't working properly
修理
After changing this part, everything works perfectly.
アドバイス
It's easy when you follow ifixit instruction.
ユーザのアバター
問題
The phone is 3+ years old and the battery would die in 3 hours of continuous usage. It also wouldn't charge unless you bend the lightning cable into the dock connector at an angle and keep it that way which is (holy ####) extremely frustrating and damages the appliance.
修理
The repair itself went with a . . .
ユーザのアバター
問題
... is the Multi Tool Roll does not come in fashion colors. I would reorder as soon as I knew I could get a green one
修理
アドバイス
... is the Multi Tool Roll does not come in fashion colors. I w . . .
ユーザのアバター
問題
no charge
修理
fantastic
アドバイス
non ascoltare solo apple
ユーザのアバター
問題
Broken hard disk cable
修理
It took only 5 minutes. Easy, fast, secure and now it's working! Don't be shy to repair something by yourself. And I've saved money!
アドバイス
First of all, practice, get familiar with your mac. Watch tutorials.
ユーザのアバター
問題
Power button was not working, and the battery was failing.
修理
It was ok. The battery was rather hard to peel out, but after that, the power button procedure was ok.
アドバイス
The guide says to un-hinge the power button before the cable is detached from the back case. I found that I had to take the volume buttons . . .
ユーザのアバター
問題
My aunt forgot the take out of the pocket her iPhone 5S before putting the jeans in the washer machine.
修理
There was no sign of sulfate or sparks on the logic board pins. We need to change the Dock port and probably the Battery but I am waiting on her desicion to spend $80 and it may be work or not.
アドバイス
Yo m . . .
ユーザのアバター
問題
The 1TB hard drive in my 2011 iMac started failing. Luckily I had everything backed up on externals. I was super excited to see that iFixit had a dual hard drive kit, so I ordered that plus a 500GB SSD for my boot drive and a 3TB HDD for bulk storage.
修理
The repair went amazingly well. A co-worker helpe . . .
ユーザのアバター
問題
Upon visiting the Apple store to complain about the useless power button that mysteriously stopped working on my iPhone, I was told that my only option was to purchase an expensive "out of warranty" replacement. Fortunately, after researching the problem, I chose to buy a repair kit from iFixit ins . . .
ユーザのアバター
問題
cant afford a new replacement phone
修理
repair went fine
アドバイス
dont need to remove the battery
もっと表示する
