Essential Electronics Toolkit
Limit 5 per customer.
$19.99
$19.99
ご希望の商品が再入荷しましたらお知らせします。
新しいバッテリー=より速いiPhone
最低購入価格 $16.99
製品詳細
特長
特長
Our most economical do-everything toolkit. The Essential Electronics Toolkit is what you need for the most essential electronics repairs—like screen and battery swaps—and everything you need for most household DIY fixes.
Get started in electronics repair with all the bits and precision tools to handle your most urgent screen breaks and battery swaps. Or simply upgrade your home DIY toolkit with what you need to service door knobs, home appliances, eyeglasses, and more.
Kit Includes
修理にまつわるストーリー
ユーザのアバター
Sean Lichtenstein's Story Photo #1330869
問題
Cracked/Smashed IPhone 6S screen
修理
It went well! A little more difficult than I expeted but the guides were a fundamental help with this repair- I would not have been able to complete it without them!
It was a bit tricky getting the Home button in place as well as the earpiece speaker and camera- but . . .
ユーザのアバター
Andrew Kubicka's Story Photo #1183403
問題
I was completely unable to use any of the functions of Wifi, bluetooth or location servies. I would not pick up any wifi networks, any bluetooth connections would connect and disconnect a few times before never connecting again, and location services could barely pick up my location (on occation up . . .
ユーザのアバター
問題
It had the 3 beep of death. I purchased 2, 8s of ram for a total of 16, however. It would not allow this. So ended up with 10gb. Initially I thought I had a bad top ram slot. But the 2gb took. But had to put them in one at a time to test them. I truly would not wanted to replace the logic board. S . . .
ユーザのアバター
問題
I replaced the battery, fan, and right speaker/subwoofer
修理
Took my time and reviewed videos over and over. Everything went smoothly.
アドバイス
for images, I would show the before and after shot of how to remove certain connections. I didn't know how to remove a certain piece from your website, but found out fro . . .
ユーザのアバター
問題
My MacBook Pro Early Rubber Feet has left and I was replace it with MBP Rubber Feet that i was buy on iFixit Store. I buy Essential Electronics Toolkits to do this.
修理
First, i replace botoom case my MacBook Pro and then replace 4 rubber feet.
Just do it.
アドバイス
You don't need adhesive 'cause iFixit MBP Rubber . . .
ユーザのアバター
問題
Still using the original battery in 2018 so decided it was time.
修理
Replacement went smoothly -- except for the enclosed tools. I recommend purchasing the toolkit to avoid stripping the screws.
アドバイス
The four screwdrivers are really just toys; please either spring for a better set of just do away with them.
ユーザのアバター
問題
Hard drive died. My first delve into computer guts. Drive seemed fine, head not stuck, but made clicking noise. Decided I wouldn't be able to recover. Maybe circuit board... Bought Evo 256Gig SSD and while looking around the delightful ifixit site, discovered the discussions about upgrading the . . .
ユーザのアバター
問題
Problems: 1) GPS was not identifying my location very well. gave a rather large cone of uncertainty and turn-by-turn directions was not usable. 2) wifi connectivity was suspect. my device had to be very close to a router to connect. 3) bluetooth connectivity was also bad. my device had to be very cl . . .
ユーザのアバター
問題
Regardless of charger or cable, charge rate was only 300 mA. New battery did not help.
修理
Even with the iFixit tools (very nice), the case got a little dinged. The glue holding the board was more tenacious than expected.
アドバイス
Take your time. Use little force. Don't bend boards or cables more than necessary. B . . .
ユーザのアバター
問題
I've previously had Apple repair the cable while it was under warranty and that cable subsequently went out about a year after that. I was able to scavenge a HD cable from another MacBook Pro (mid 2011) and while not ideal, it worked well enough. Now I had the money and time to double down on the ca . . .
もっと表示する
