Detailing Brush
  • Detailing Brush / Nylon
  • Detailing Brush / Brass
Detailing Brush
$2.99
$2.99
ご希望の商品が再入荷しましたらお知らせします。
Free shipping on all orders over $100.00 or containing a Pro Tech Toolkit!
当社のショップを閲覧する
Ever fixed something? That’s Genius.
Share your repair story with #ImAGenius
We Are All Geniuses
製品詳細
概要
概要
No more worn out toothbrushes with bent bristles, these economic professional tools will do the job faster and better, fitting into more places, and don't require handle bending pressure to do a good job. These bristles are ready to scrub and clean with minimal effort.
This double ended brush will fit in tight spaces and quickly cleans up battery acid damage, residue from spills, corrosion from water damage, dust, and thermal paste residue.
メモ
This brush is safe for most applications, but is not an official "ESD safe" tool.
修理にまつわるストーリー
ユーザのアバター
問題
Water damage on a macbook pro.
There was a dime sized bit of corrosion on the logic board and it would not turn on.
修理
Pulled the back off, unhooked the battery, stogged the corroded bits with a really soft brush and alcohol. Let it dry, put it back together and it turned back on.
アドバイス
Be brave...
ユーザのアバター
問題
I am just starting out in the repair business, I repair all sorts of electronics, mainly the repairs are either Mobile Devices, Laptops, Computers. IFIXIT.com has a lot of the tools that are required for repairing these devices.
修理
Repairs go a lot quicker with the right tools.
アドバイス
Make sure you have the ri . . .
ユーザのアバター
問題
Bass from speakers just come out as muddled.
修理
Removed without much trouble.
アドバイス
The original screws securing the sub-woofer strips quit easily. Pay attention when removing them. I had to discard one screw I stripped. Luckily I could remove them by forcing the screwdriver into the screw to create new indent . . .
ユーザのアバター
問題
Silly Tri-Tip screwdrivers, lucky ifixit came to the rescue!
修理
Excellently
アドバイス
Make sure you order the right battery from Amazon, it's too bad that ifixit doesn't stock batteries for newer Macbook Pro's
ユーザのアバター
問題
Just needed some more tools for opening Apple Mac's, Getting out laptop screws that have had there heads destroyed and the magnetic project mat for the laptop screws.
修理
Always good
アドバイス
By the right tools for the right job and it always easier.
もっと表示する
