64 Bit Driver Kit
64 Bit Driver Kit
All the screwdriver bits you need to repair electronics, smartphones, tablets, computers, game consoles, and wearables in one handy toolkit.
$24.95
$24.95
ご希望の商品が再入荷しましたらお知らせします。
製品詳細
特長
特長
The ultimate high-performance bit kit
  • The complete screw-turning solution for precision repair jobs.
  • Custom handle with two-zone grip profile provides up to 8.5 N-m of torque.
    • Textured precision zone for delicate screw turning
    • Three-faceted, large-diameter grip zone for heavy duty wrenching.
  • 64 purpose-driven screwdriver bits selected based on the data from thousands of repair guides.
  • This bit kit contains bits to repair cell phones, game consoles, wearables, laptops, desktops, tablets, small appliances, and much more!
  • The specially-designed case conveniently holds and displays all the contents in high-density foam.
  • The lid of the case features an integrated sorting tray.
  • Ergonomic Aluminum Handle provides plenty of torque and grip with swivel cap and magnetized bit holder.
Interested in purchasing more than 10? Contact Us!
Kit Includes
  • 64 Bit Driver
  • 150 mm Flex Extension
  • 4 mm Screwdriver Bits
    • Phillips - 000, 00, 0, 1, 2
    • Flathead - 1, 1.5, 2, 2.5, 3, 4 mm
    • Torx - T2, T3, T4, T5
    • Torx Security - TR6, TR7, TR8, TR9, TR10, TR15, TR20, TR25
    • Pentalobe - P2, P5, P6
    • JIS - J000, J00, J0, J1
    • Hex - 0.7, 0.9, 1.3, 1.5, 2, 2.5, 3, 3.5, 4, 4.5, 5 mm
    • Tri-point - Y000, Y00, Y0, Y1
    • Nut Driver - 2.5, 3, 3.5, 4, 4.5, 5, 5.5 mm
    • Square - 0, 1, 2
    • Gamebit - 3.8, 4.5 mm
    • Spanner - 4, 6, 8
    • Triangle - 2, 3 mm
    • SIM Eject Bit
    • 1/4" to 4 mm Driver Adapter
製品ビデオ
修理にまつわるストーリー
ユーザのアバター
Dhruv Patel's Story Photo #1157370
Dhruv Patel's Story Photo #1157371
Dhruv Patel's Story Photo #1157372
問題
It was a broken hard drive so I decided to disassemble it for the magnets and other parts inside.
修理
It went well. No problems encountered.
アドバイス
The Linus Tech Tips video is really useful. Also if the torx is slightly too big for your torx bits, you can use torx security bits on regular torx screws.
ユーザのアバター
Gavin Hobbs's Story Photo #1191523
Gavin Hobbs's Story Photo #1191524
問題
The battery life wasn't the greatest and the battery icon had an alert that notified me that it needed checking. Additionally, the touchpad's click wasn't working... only the tap.
修理
The repair went perfectly! I found a whole bunch of dust and stuff and cleaned it out with the vacuum hose.
アドバイス
Take it slowly . . .
ユーザのアバター
問題
I needed another tool kit
修理
Successful so far
アドバイス
Well I needed a second repair kit because I'm constantly working on things at work and at home and my current kit was always in the wrong place. So I messaged iFixit about their 64bit driver set. Asking if it was aluminum and freaking Kadan made me laugh so . . .
ユーザのアバター
問題
My GTX 980 Founders Edition was full of dust and the joysticks on my controllers were acting up.
修理
It went great I disassembled the 980 and controllers, I cleaned every spec of dust out and now my 980 is running much cooler and my controllers are working perfectly
アドバイス
Get a 64 bit driver they have every bi . . .
ユーザのアバター
問題
The problem is I ordered my original kit from a competitor that I'm sure if you do a quick google search on iPhone 7 plus screen replacement kit they pop, anyway I ordered the kit and the it came the instruction manual and the Y000 bit was not inside the kit, only after complaining about my frustrat . . .
ユーザのアバター
問題
Shattered screen. Replaced the panel
修理
Extremely easy with ifixits guide and tools. Found out my girlfriend was cheating because I was being nice and fixed her phone so that part didn’t go so well.
アドバイス
The repair guides for the panel do not include links to go to the next stage, ie if youre replacing the . . .
ユーザのアバター
問題
Running slowly
修理
Perfectly
アドバイス
Best tools ever
ユーザのアバター
問題
Bad heads, PCB issues, etc.
修理
I use this kit regularly for my recovery jobs. I get many different hard drives coming into my shop: WD, Seagate, Hitachi, Fujitsu, Toshiba, etc. and they come with all kinds of issues. Everything from deleted files to platter damage. You name it, I see it. This kit is an . . .
ユーザのアバター
問題
PlayStation 4 stopped working and figured it was the power supply
修理
Put the new power supply in and it started up right away
アドバイス
Always make sure you know the part number before starting any work. You do that you'll never have to worry if you ordered the right one
ユーザのアバター
問題
My wife's late 2014 MacMini needed a HDD upgrade as the stock HDD was killing performance.
修理
The repair went well. No issues to report. It went back together easier than others have reported.
アドバイス
Be very careful with the power supply assembly. If you have to force it back in it's not aligned correctly.
もっと表示する
この商品を購入された方は次の商品も購入されています。
