iMac Intel 27" Mid 2011 Dual Hard Drive Kit
$19.99
$19.99
ご希望の商品が再入荷しましたらお知らせします。
新しいバッテリー=より速いiPhone
最低購入価格 $16.99
製品詳細
特長
特長
Dual drive power in your 27" iMac.
  • The complete kit includes all the tools and cables you need to install a second drive. Just add an iMac and new hard drive or SSD of your choice.
  • This kit is compatible with all processor speeds, regardless of whether or not Apple offers the additional SSD option for your machine.
  • This kit does not require permanently removing your optical drive.
  • We recommend installing an SSD and using it as your boot drive or a 1 TB hard drive for more storage space.
Note: this kit will only work in Mid 2011 27" iMacs. We also offer an equivalent dual hard drive kit for the Mid 2011 21.5" iMac.
Fix Kit includes:
Part Only Kit includes:
  • Custom SATA power & data cable
  • Custom-cut 3M mounting tape
互換性
iMac Intel 27" EMC 2429
2.7 GHz (Mid 2011)
3.1 GHz (Mid 2011)
3.4 GHz (Mid 2011)
修理にまつわるストーリー
ユーザのアバター
Ian Schrader's Story Photo #1334230
Ian Schrader's Story Photo #1334231
Ian Schrader's Story Photo #1334232
問題
The original HDD crashed.
修理
Very smooth. The how-to was right on the money. I chose to fully remove the logic board and blow out the internals with a can of air while I had it open. Was also able to finally rescue an SD card that had been lost to the Superdrive for a couple of years.
アドバイス
Take your time. . . .
ユーザのアバター
Dan Ringer's Story Photo #1265737
Dan Ringer's Story Photo #1265739
Dan Ringer's Story Photo #1265741
問題
It was showing its age. Our 2013 MacBook Pro was running circles around it but cpu benchmarks show it as similar. Only difference? SSD.
修理
Very well.
アドバイス
Read through all the steps, and the comments but others who’ve tried it. And the YouTube video from OWC.
ユーザのアバター
Sebastian's Story Photo #872819
Sebastian's Story Photo #872820
Sebastian's Story Photo #872821
問題
My iMac first started showing symptoms by rebooting intermittently. A few days later, the infamous thick bars would appear on the display, at which point the iMac would reboot. The computer would boot back to the desktop and would be usable for a very short period of time before repeating the cycle. . . .
ユーザのアバター
Joshua Collins's Story Photo #1331226
Joshua Collins's Story Photo #1331225
問題
2011 iMac was soooo slow. Like "click an app, go do errands, come back it's open (unless it crashed already)" kind of slow. Also 1 TB hard drive getting fuller and not helping the slowness.
修理
Repair went well. Found out that Apple added some extra screws and casing when I got my Superdrive replaced a . . .
ユーザのアバター
Alan's Story Photo #997799
Alan's Story Photo #997800
問題
I had a friend who had bought, 2nd hand, a mid 2011, 27" iMac for his son and wanted to install an SSD into it to move the OS onto.
修理
The repair went well up until the part after removing the optical drive. It was at this point that I started to get suspicious (whereas in reality I should have spotted . . .
ユーザのアバター
mattgow's Story Photo #873326
問題
Wanted to add a fast SSD drive to an old iMac without removing existing HDD or optical
修理
The repair went fine. It's a bit tedious (thanks Apple) but not crazy.
アドバイス
The screws holding the monitor in place are a pain to put back in due to the strong magnets nearby. Hold each screw tightly with a pair of needl . . .
ユーザのアバター
問題
My iMac (mid 2011) kept restarting and stayed in that cycle. It would come up to the white screen with the Apple and shut down again. I am hours away from an Apple Store and I work on computers at my job so I thought I'd give it a try.
修理
Turns out that I needed to use my 1GB external Hard Drive I use f . . .
ユーザのアバター
問題
Wanted to make the computer faster by adding an SSD.
修理
It wasn't easy but the guide was spot on and the tools were completely appropriate. Just such small gaps and connectors for my clumsy big man hands.
アドバイス
Worked as described in the tutorial but frustrating for the average adult man. But so happy with the . . .
ユーザのアバター
問題
Replaced main hard drive with new ssd
修理
Repair went good. Instructions were well detailed and I was easily able to add new ssd.
アドバイス
Instructions did not warn that as soon as you add a none apple hard drive that the fan will go max speed. Was able to find a 3rd party app on my own to make the fan use an inte . . .
ユーザのアバター
問題
I just need to speed up the read and write speed of the disk, installing and using a second hard drive such as SSD will do the job.
修理
Taking out the optical drive and replacing it with an SSD went well just having some difficulty in putting back the logic board it took me a while to insert in back in t . . .
もっと表示する
