MacBook Unibody (A1278) Hard Drive Cable
  • MacBook Unibody (A1278) Hard Drive Cable
  • 360°
360
$39.99
$39.99
ご希望の商品が再入荷しましたらお知らせします。
iPhone X用修理キット
Warranty up? No worries, we’ve got the fix.
ショップを見る
iPhone X用修理キット
ショップを見る
製品詳細
概要
概要
Replace a broken or damaged hard drive cable compatible with a Model A1278 MacBook Unibody with this part.
This cable connects the hard drive to the logic board.
互換性
互換性
  • MacBook 13" Unibody A1278 2 GHz and 2.4 GHz
仕様
仕様
Part #:
922-8623
互換性
修理にまつわるストーリー
ユーザのアバター
問題
Macbook fell off the shoulder bag of my brother inlaw.
Booting from an external hd worked fine, so i figured it was either the cable or the hd. Since the hd was OK, cable was broken.
修理
Ordered in express the appropriate cable, opened the dusty beast (2008 Macbook), and fixed it. Took the opportunity t . . .
ユーザのアバター
問題
Replaced old platter drive with Samsung Evo 256gb SSD. Screen would show "no bootable device" during boot, even though I cloned the hdd to the ssd prior to installation. Read online about possible problems with the sata ribbon cable, so I decided to replace it.
修理
It was not easy getting the ribbon cab . . .
ユーザのアバター
問題
My MacBook stopped working with the harddrive. Tried everything, then i found an artikel that in most cases it is a problem with the Hard Drive Cable. And I found IFIXIT.
修理
First of all I ordered this cable from Denmark (Europe). To start with, I ordered a wrong cable witch I received after approx. 7-1 . . .
