MacBook Pro MagSafe Boards
Grab a toolkit for your MacBook Pro model and fix your broken laptop!
iFixit has you covered with parts, tools, and free repair guides. Repair with confidence! All of our replacement parts are tested to rigorous standards and backed by our industry-leading warranty.
お持ちの MacBook Pro モデルを選択:
MacBook Proで使用されているパーツ:
MacBook Pro Unibody 13" and 15" MagSafe DC-In Board
Replace a damaged or malfunctioning magnetic DC power connector.
MacBook Pro 15" Retina (Late 2013-Mid 2015) MagSafe 2 DC-In Board
Replace a broken or damaged MagSafe 2 DC-in board for your Late 2013 to Mid 2015 MacBook Pro 15" Retina laptop with this part. This part connects the wall adapter power t...
MacBook Pro 13" Retina (Late 2013-Early 2015) MagSafe 2 DC-In Board
Replace a broken or damaged MagSafe 2 DC-in board for your Late 2013 to Early 2015 MacBook Pro 13" Retina laptop with this part. This part connects the wall adapter power...
MacBook Pro 15" Retina (Mid 2012-Early 2013) MagSafe 2 DC-In Board
Replace a broken or damaged MagSafe DC-in board for your Mid 2012 or Early 2013 MacBook Pro 15" Retina laptop with this part. This part connects the wall adapter power to...
MacBook Pro 13" Retina (Mid 2012-Early 2013) MagSafe 2 DC-In Board
This part connects the AC wall adapter power to the logic board.
MacBook Pro 17" Unibody (Mid 2010-Late 2011) MagSafe DC-In Board
Replace a broken or damaged MacBook Pro 17" Unibody (Mid 2010 to Late 2011) MagSafe DC-In Board.
MacBook Pro 17" Unibody (Early-Mid 2009) MagSafe DC-In Board
This part connects the wall adapter AC power to the logic board.
MacBook Pro 15" (Model A1260) Left I/O Board
Replace an I/O board compatible with the model A1260 MacBook Pro 15" laptop. Fix problems with charging, audio, and data connections. Includes the MagSafe power, USB, and...
MacBook Pro 17" (Model A1151) Left I/O Board
Replace an I/O board compatible with the model A1151 MacBook Pro 17" laptop. Fix problems with charging, audio, and data connections. Includes the MagSafe power, 2 USB po...
MacBook Pro 17" (Model A1261) Left I/O Board
Replace an I/O board compatible with the model A1261 MacBook Pro 17" laptop. Fix problems with charging, audio, and data connections. Includes the MagSafe power, 2 USB po...
デバイスの情報
Catering to the working professional, the MacBook Pro is aptly named. With powerful processor and graphics capabilities, these Apple machines are great for either the professional or aspiring creative genius.
We sell dozens of MacBook Pro upgrades and repair parts. It's easy, fast, and safe to max out your machine! Two RAM slots allow for an easy memory boost. Need more storage? Drop in a larger-capacity 500 GB 7200 RPM 9.5mm SATA hard drive for some much-needed space as well as speed. An 85-watt MagSafe adapter will keep your machine juiced through even the most power demanding processes.
Select your version above for parts and assistance!
