修理を始めるには
修理する権利
ストア
Parts Mac MacBook Pro Display Components
ストア
Grab a toolkit for your MacBook Pro model and fix your broken laptop!
iFixit has you covered with parts, tools, and free repair guides. Repair with confidence! All of our replacement parts are tested to rigorous standards and backed by our industry-leading warranty.
モデルを確認されたい方 お持ちのMacのモデル番号を確認する
MacBook Pro 15" (Models A1226/A1260) Front Display Bezel
Replace a damaged bezel without the cost of a new LCD
$139.99
MacBook Pro 15" (Models A1150/A1211) Display Inverter
A bad inverter board can cause a dead backlight
$14.99
MacBook Pro 17" (Models A1151/A1212/A1229) Display Data Cable
Replace a damaged or malfunctioning cable connecting the LCD panel to the logic board.
$49.99
MacBook Pro 15" (Model A1150) Clutch Cover
Houses the hinges and airport antenna assembly.
$9.99
MacBook Pro 17" (Model A1151/A1212) Display Inverter
Replace a malfunctioning inverter board in a 17" MacBook Pro. A bad inverter can cause a dead backlight.
$69.99
MacBook Pro 15" (Model A1150) Antenna Cover
This antenna cover houses the airport antenna assembly compatible with the Model A1150 EMC 2101 15 inch MacBook Pro laptop. Part #922-7279.
$9.99
MacBook Pro 17" (Model A1212) Clutch Cover
Replace a faulty, cracked or broken LCD hinge clutch cover on your MacBook Pro 17".
$19.99
MacBook Pro 15" (Models A1150/A1211) Rear Display Bezel
$59.99から
MacBook Pro 17" (Model A1212) Antenna Cover
Replace an Antenna Cover compatible with the A1212 model 17" MacBook Pro laptop. This part houses the AirPort antenna cable assembly within the clutch cover.
$19.99
MacBook Pro 15" (Models A1211/A1226) Airport Antenna Cables
Replace the antenna cables and the assembly that rests inside the antenna cover compatible with the A1211 or A1226 model 15 inch MacBook Pro laptop.
$19.99
製品を表示 19の1−10
デバイスの情報
Catering to the working professional, the MacBook Pro is aptly named. With powerful processor and graphics capabilities, these Apple machines are great for either the professional or aspiring creative genius.
We sell dozens of MacBook Pro upgrades and repair parts. It's easy, fast, and safe to max out your machine! Two RAM slots allow for an easy memory boost. Need more storage? Drop in a larger-capacity 500 GB 7200 RPM 9.5mm SATA hard drive for some much-needed space as well as speed. An 85-watt MagSafe adapter will keep your machine juiced through even the most power demanding processes.
Select your version above for parts and assistance!
