MacBook Pro 17" (Model A1261) Right Fan
  • MacBook Pro 17" (Model A1261) Right Fan
$39.99
$39.99
ご希望の商品が再入荷しましたらお知らせします。
iPhoneのバッテリーキット
Only $29.99
Buy Now
iPhoneのバッテリーキット
Only $29.99
Buy Now
製品詳細
概要
概要
Replace a malfunctioning or noisy fan compatible with a Model A1261 17" MacBook Pro.
If your screen is facing you, this is the fan on the right side of the machine. Includes fan and surrounding metal bracket.
Looking for the Left Fan?
互換性
互換性
  • MacBook Pro 17" A1261 Early 2008 and Late 2008
仕様
仕様
Part #:
922-8396
互換性
修理にまつわるストーリー
ユーザのアバター
問題
After many years, my beloved MacBook Pro 17 (early 2008 - A166X), was about to "byte" the dust (yes, pun intended). I had heard some intermittent noise occasionally, but it had always gone away. Now it was consistent, loud (annoyingly so), and starting to make the system overheat. (I verified this b . . .
ユーザのアバター
問題
The right fan in my MacBook Pro 17" was making an annoying whine. The fan was dying.
修理
Thanks to iFixIt and the great instructions on the website for replacing a right fan the repair went very well. I had a friend who works with computers help me. The instructions were very helpful for him.. It took ab . . .
ユーザのアバター
問題
After 7 years of constant use, right fan bearing was going bad making moaning/grinding noise
修理
Slicker than snot on a griddle - 20 min total from start to finish only because some of the tiny Phillips screws were reluctant to go back in.
アドバイス
Nothing to add - between the part/spudge and online guides everyth . . .
ユーザのアバター
問題
The right fan on my MBP sounded like a chain-wielding demon hampster running on its torture wheel.
修理
20 minutes after the parts were delivered, the computer was up and going silently again. Ifixit's instructions were clear and easy to follow.
アドバイス
Be careful with all the tape, especially the aluminum/copper . . .
ユーザのアバター
問題
The right fan had become very loud.
修理
I first tried to just clean the fan blades, as others on the web have noted. But the blades are fragile and I managed to break one off while cleaning. Even though I was being quite careful.
So I bought a new fan. I decided to replace both fans as both were dirty . . .
ユーザのアバター
問題
My MBP right cooling fan had been "talking" to me for years, soft ticks and growls. Then it began screeching solid and loud. The shaft was in critical orbit mode.
修理
The part arrived early the next day (all it takes is money) and I was up and running by 11:00 am. I followed the steps and photos, la . . .
ユーザのアバター
問題
Right fan started to make a grinding noise.
修理
The repair went very smooth.
start to finish time about 30mins.
アドバイス
The hardest part is the plugin for the fan. It is a little goofy to install, press down, don't try to slide it in.
ユーザのアバター
問題
Noisy right fan ended up dead
修理
Quite easy. Took about half an hour. But the brand new Phillips #0 Screwdriver didn't last - the tip broke off although handled with care - made it difficult to reassemble the machine. A bit annoying.
アドバイス
The photo of the macbookpro 17" model A1261 Fan shown in the iFixit Gui . . .
ユーザのアバター
問題
The right fan on my MacBook was running very loudly and had become almost unbearably noisy at full speed.
修理
I ordered the replacement fan and the tool kit that was on sale - one cannot have too many tools can one?
The repair went very smoothly - the guides provided online were very descriptive . . .
ユーザのアバター
問題
very noisy fan
修理
very good, it took me less than 1 hour without hurrying. First time I opened a laptop in my life so the instructions were very useful.
アドバイス
make sure you know how to disconnect the cables to prevent damage: pull up/sideways.. etc.
もっと表示する
