MacBook Pro 17" (Model A1261) Left Fan
  • MacBook Pro 17" (Model A1261) Left Fan
$39.99
$39.99
ご希望の商品が再入荷しましたらお知らせします。
MacBook Battery 修理キット
最低価格 $69.99
Buy Now
最低価格 $69.99
Buy Now
製品詳細
概要
概要
Replace a malfunctioning or noisy fan compatible with a Model A1261 17" MacBook Pro.
If your screen is facing you, this is the fan on the left side of the machine.
Looking for the Right Fan?
互換性
互換性
  • MacBook Pro 17" A1261 Early 2008 and Late 2008
仕様
仕様
Part #:
922-8395
互換性
修理にまつわるストーリー
ユーザのアバター
問題
Laptop was running really hot. Fan control utility showed left fan was not running. 0 RPM.
修理
Outstanding. Followed repair guide easily
アドバイス
Add recommendation for cleaning dust from fan exit ports. Remove both fans and clean dust. Tooth picks and Q-tips worked
Add link in guide for removing and reconnec . . .
ユーザのアバター
問題
Fan was noisy
修理
Part came in when expected and was correct. Used the Ifixit guide to tear down and replace the fan which went with no issue. Did have an issue with the Mac's top case where the front inside screw attachment brackets spot welds failed (not happy with Apple's quality here), but everythi . . .
ユーザのアバター
問題
The right fan had become very loud.
修理
I first tried to just clean the fan blades, as others on the web have noted. But the blades are fragile and I managed to break one off while cleaning. Even though I was being quite careful.
So I bought a new fan. I decided to replace both fans as both were dirty . . .
ユーザのアバター
問題
Left fan was noisy enough to be heard from the next room.
修理
First try was on the previous weekend -- I used the guide to take out the noisy fan, disassembled it, cleaned it, and applied some lube. Put everything back together, fired it up, and there was blessed silence.
For ten minutes.
Ten min . . .
ユーザのアバター
問題
Funny thing. The sensors acted weird - it even wrote messages by itself.
修理
Same procedure as always - just follow the tutorial.
アドバイス
After changing the iPhone display, the phone might not start up with just the backlight on. Don't panic, just do a forced reboot (Home + Power button until you see the apple)
ユーザのアバター
問題
Noisy fans in the MacBook Pro made using the laptop nearly impossible. The high pitch whiny rattle was loud and obnoxious at times and what Apple wanted to charge to fix it was like taking out a second mortgage. So when I found iFixit with guides on "how to" I thought why not?
修理
The guides didn't make . . .
ユーザのアバター
問題
Left fan was making loud grinding sound, so both fans replaced to avoid future problems with right fan
修理
Instructions were very good with easy step by step procedures.
アドバイス
FOLLOW THE INSTRUCTIONS, make sure the i-sight cable and converter cables are properly connected before closing the case. Use something . . .
ユーザのアバター
問題
The MacBook was too warm!
修理
All OK! It was necessary about 8 housr of work (disassembly and re-assembly the MacBook)
アドバイス
もっと表示する
