修理を始めるには
修理する権利
ストア
MacBook Pro 15" Unibody (Late 2008 - Late 2011) LCD Panel
  • MacBook Pro 15" Unibody (Late 2008 - Late 2011) LCD Panel
$84.99
$84.99
製品詳細
商品名
商品名
Replace a damaged or malfunctioning 15.4" LCD panel in your MacBook Pro 15" Unibody (Late 2008-Late 2011) model laptop.
A new LCD panel can restore dead pixels, fix color bleeding, and eliminate lines in your display image as well as restore a dim or dead backlight.
互換性
互換性
  • MacBook Pro 15" Unibody A1286 Late 2008 to Late 2011
仕様
仕様
Part #:
LP154WP3-TLA3, LP154WP4-TLA1
Resolution:
Standard: 1440x900
High: 1680x1050
Diagonal Size:
15.4"
互換性
MacBook Pro 15" Unibody 2.53 GHz Mid 2009
A1286 (EMC 2324) 2.53 GHz
MacBook Pro 15" Unibody Early 2011
A1286 (EMC 2353-1) 2 GHz
A1286 (EMC 2353-1) 2.2 GHz
A1286 (EMC 2353-1) 2.3 GHz
MacBook Pro 15" Unibody Late 2008 & Early 2009
2.66 GHz
2.93 GHz
A1286 (EMC 2255) 2.4 GHz
A1286 (EMC 2255) 2.53 GHz
A1286 (EMC 2255) 2.8 GHz
MacBook Pro 15" Unibody Late 2011
A1286 (EMC 2563) 2.2 GHz
A1286 (EMC 2563) 2.4 GHz
A1286 (EMC 2563) 2.5 GHz
MacBook Pro 15" Unibody Mid 2009
A1286 (EMC 2325) 2.66 GHz
A1286 (EMC 2325) 2.8 GHz
A1286 (EMC 2325) 3.06 GHz
MacBook Pro 15" Unibody Mid 2010
A1286 (EMC 2353) 2.4 GHz
A1286 (EMC 2353) 2.53 GHz
A1286 (EMC 2353) 2.66 GHz
A1286 (EMC 2353) 2.8 GHz
3以上のデバイスを表示する
修理にまつわるストーリー
ユーザのアバター
patrash's Story Photo #229687
patrash's Story Photo #229688
問題
LCD on MacBookPro was damaged and didn´t work properly
修理
Like a charm!
It was a bit hard no exactly know how much heating had to be done to ensure that display glam could be removed from adhesive edge around the display. I think I accidently heated it too much and a huall area of the glam became a bi . . .
ユーザのアバター
問題
My lcd was bad
修理
As many others have said, getting the glass off was real tough, I found that when I wasn't having success in one corner, I tried a lower corner and it worked much better. From there I just pried all the way around, making sure to heat a bit as I went.
アドバイス
I bought my led from Ifixit and the . . .
ユーザのアバター
問題
I always try to fix things myself, and my wifes laptop screen was not going to be an exception.
修理
Easy! Simple! Step by step instructions that even a monkey can learn to follow. This was my first time ever working on electronics, so it was a bit intimidating at first, but very easy. The parts i ordered . . .
ユーザのアバター
問題
Back of aluminum had something fall on it and dented right into the lcd , and broke it.
修理
Very well , easy followed instructions did it in just under an hour for disassembling . Part arrived the next day put it in and reassembled in less time .
I had to drill out some stripped screws .. No big deal . . . .
ユーザのアバター
問題
Il mio schermo LCD é morto ,fuori garanzia ovviamente costo riparazione 600 euro e più. Dopo aver messo del disossidante per contatti sul connettore dello schermo ha ricominciato a funzionare , peccato che abbia rovinato lo schermo
修理
Riparazione avvenuta con successo, a parte gli insetti dentro lo sc . . .
ユーザのアバター
問題
Screen was smashed so I had to fix it
修理
This was not easy, but definitely worth the work. The instructions on this website are superb
アドバイス
Make sure to keep track of which screws go where!
ユーザのアバター
問題
Lcd was broken, its cheaper do it by yourself
修理
LCD was replaced flawlessly... the front glass didnt had the same fate.
アドバイス
remove the front glass is very tricky, better consider have a spare front glass handy
ユーザのアバター
問題
Broken LCD w/ verticle bands of solid white/black.
修理
Reasonably well. Used a hair dryer instead of a heat gun. Had a lot of trouble getting LVDS cable (also replaced) to stay in the lcd when putting everything back together.
アドバイス
My LCD panel has about 50 stuck red pixels all in a clump in the lower left cor . . .
ユーザのアバター
問題
My mac took a bit of a tumble and the bottom quarter of the screen was distorted to just lines. Took it into to an Apple store to make sure it was the right problem and see if it would at least be around the same price as fixing it myself, but ~$500 was a little pricey for me.
修理
I only had two issues c . . .
ユーザのアバター
問題
The late-2008 Macbook Pro 15" - after a lightning discharged quite nearby the screen acquired a bad habit of turning white washed out. Could be a coincidence or just a factor promoting a defect.
The washout could be remedied by a little pinching of the screen - so it was just a matter of time the g . . .
さらに表示する
