修理を始めるには
修理する権利
ストア
MacBook Pro 15" Unibody (Early 2011-Mid 2012) Upper Case
  • MacBook Pro 15" Unibody (Early 2011-Mid 2012) Upper Case
$299.99
$299.99
製品詳細
商品名
商品名
Replace a broken or damaged upper case, backlit keyboard, and battery level indicator assembly compatible with the Early 2011 to Mid 2012 MacBook Pro 15" Unibody laptop.
以下はパーツの組み立て一覧です。
以下はパーツの組み立て一覧です。
  • Upper Case
  • Backlit Keyboard
  • Battery Level Indicator
互換性
互換性
  • MacBook Pro 15" Unibody A1286 Early 2011 to Mid 2012
仕様
仕様
Part #:
661-5854, 661-6076
互換性
MacBook Pro 15" Unibody Early 2011
A1286 (EMC 2353-1) 2 GHz
A1286 (EMC 2353-1) 2.2 GHz
A1286 (EMC 2353-1) 2.3 GHz
MacBook Pro 15" Unibody Late 2011
A1286 (EMC 2563) 2.2 GHz
A1286 (EMC 2563) 2.4 GHz
A1286 (EMC 2563) 2.5 GHz
MacBook Pro 15" Unibody Mid 2012
A1286 (EMC 2556) 2.3 GHz
A1286 (EMC 2556) 2.6 GHz
A1286 (EMC 2556) 2.7 GHz
修理にまつわるストーリー
ユーザのアバター
kennyfoner's Story Photo #246171
問題
ユーザのアバター
問題
The keyboard had keys that weren't working.
修理
Thanks to the repair guide, the repair went very smoothly.
アドバイス
1. Print out the guide and number little plastic baggies with the step number screws and small parts.
2. The trackpad connect/disconnect seemed to be missing, look it up on YouTube.
3. Take you . . .
ユーザのアバター
問題
Coffee everywhere.
修理
Flawless. Took about 1.5 hours. I had already had this thing apart a few times so I felt like an expert... probably would have taken longer otherwise.
アドバイス
- An empty icecube tray with post-it notes is a great way to keep track of screws and small parts along the way.
- Photos are a goo . . .
ユーザのアバター
問題
My son spilled a glass of water on my wife's 2011 early macbook pro. The keyboard and trackpad no longer behaved properly
修理
The repair took a long time. It was difficult. But in the end it was successful.
アドバイス
Take your time. It is a good idea to have an egg carton or ice tray (or two) to keep screws sorted . . .
ユーザのアバター
問題
A client called with an issue.. "I spilled a DR Pepper on my my Macbook Pro *last week* and the keyboard stopped working. I used it with an external but now I get nothing." So, it's iFixit to the rescue. I searched for a replacement but all the pieces separate were just outrageous, but iFixit had it . . .
ユーザのアバター
問題
Well the wife forgot the Mac was nearby while watering a plant and that was all it took. She didn't turn it off and tried to shake the water out. I let it sit for a few day after getting the water out of it, but the keyboard was toast.
修理
All went pretty much according to the guide. The display cable wa . . .
ユーザのアバター
問題
I spilled wine on my laptop keyboard. It worked fine initially, but by the next morning, keys would not function and it became impossible to use. Not wanting to buy a new machine or send off the computer to Apple for an expensive repair, I bought the parts and tools straight from iFixit. I found . . .
ユーザのアバター
問題
My MacBook Pro's upper case didn't look to good, after it fell like 1 meter. The internal parts survived the drop without any damage - yay!
修理
Definitely not an easy repair. The repair took me more than an hour.
アドバイス
You'll need a good brain or some sort of system to know, where which screw goes...
ユーザのアバター
問題
I spilled coffee over keyboard. So the keyboard didn't work anymore.
修理
With the instruction on ifixit website, it was quite easy and nothing complicated. Just needed proper tools and took time for me. Because it was the first time that I repair my computer by myself.
アドバイス
The most difficult part for me was t . . .
ユーザのアバター
問題
I spilled a soda all over my laptop. After drying it out, the only problem was the keyboard no longer worked correctly. Very sticky keys.
修理
It was great. Followed the directions to a tee. Worked perfectly.
アドバイス
GET THE TOOLS... Tried to take apart some of this with my own tools and stripped two screws.. . . .
さらに表示する
