修理を始めるには
修理する権利
ストア
MacBook Pro 15" (Model A1260) Display Assembly
  • MacBook Pro 15" (Model A1260) Display Assembly
$149.99
$149.99
製品詳細
商品名
商品名
This MacBook Pro 15" (Model A1260) Display Assembly replacement display includes all of the small parts preinstalled in the assembly, saving time and increasing the quality of your repair.
An aging or battered laptop display may suffer a flickering image, dead pixels, or a dim backlight. Surface scratches can further degrade the image and a dented or warped case may pinch the display causing bright spots. Eliminate these flaws with a replacement LCD display assembly. Our displays are individually tested and guaranteed to function perfectly.
以下はパーツの組み立て一覧です。
以下はパーツの組み立て一覧です。
  • 1440 x 900 pixel 15.4" LCD Screen
  • Display Cover
  • Bezel
  • iSight Camera
  • Clutch Hinges
  • Display Inverter
  • Wi-Fi Antenna
  • Display Data Cables
互換性
互換性
  • MacBook Pro 15" A1260 Early 2008
仕様
仕様
Part #:
661-4609, 661-4610
Resolution:
1440x900
Diagonal Size:
15.4"
互換性
MacBook Pro 15" Core 2 Duo Models A1226 & A1260
A1260 (EMC 2198) 2.4 GHz (Penryn)
A1260 (EMC 2198) 2.5 GHz (Penryn)
A1260 (EMC 2198) 2.6 GHz (Penryn)
修理にまつわるストーリー
ユーザのアバター
Susan's Story Photo #369372
Susan's Story Photo #369377
Susan's Story Photo #369378
問題
My Macbook Pro is early 2008. Right side of screen started striping, then eventually went black. Apple wanted $600 and time to find the part. I found it on ifixit for $150. I elected to get the display AND housing, rather than take apart the display housing and pull out the display screen (soldering . . .
ユーザのアバター
問題
I've already known how to substitute a mac book pro's display due an older problem with my iSight.
修理
The repair went pretty good, I didn't get any kind of problem.
アドバイス
be careful while doing this operation.
