修理を始めるには
修理する権利
ストア
MacBook Pro 15" (Model A1211) Left I/O Board
  • MacBook Pro 15" (Model A1211) Left I/O Board
  • 360°
360
$29.99
$29.99
製品詳細
商品名
商品名
Replace a damaged or corroded I/O board for your model A1211 MacBook Pro 15" and fix problems with charging, audio, and data connections.
  • Includes the MagSafe power, USB, and audio ports.
  • Includes slots for internal Airport wireless card and PC Card ExpressCards.
互換性
互換性
  • MacBook Pro 15" A1211
仕様
仕様
Part #:
922-7911, 820-2055-A
互換性
MacBook Pro 15" Core 2 Duo Model A1211
A1211 (EMC 2120) 2.16 GHz
A1211 (EMC 2120) 2.33 GHz
修理にまつわるストーリー
ユーザのアバター
問題
Old Macbook Pro, no longer charging. I thought this laptop was consigned to the bin as the repair would have cost hundreds (at least that's what I thought!)
修理
It went surprisingly well and with very little collateral damage to other systems
アドバイス
1) Make sure you've got lots of space
2) Make sure that space i . . .
ユーザのアバター
問題
Working on my 2006 MBP , computer suddenly shut down, no warning of low battery, nothing. I immediately plugged in the charger, and noticed that the mag. plug did not / would not change to the orange charging state. I then checked the battery, ¾ charged. I managed to get the MBP laptop running . . .
ユーザのアバター
問題
A friend of mine dropped her macbook pro while it was charging and the magnet jack broke. She took it to an apple store to see about repairs, but out of warranty she was quoted 500$+ to repair it. She has 4 kids and is a single mom she could not afford the repairs or a new laptop, since I have exp . . .
ユーザのアバター
問題
Went to plug in the magsafe adapter into the MBP and got a juicy static electric discharge at the connector. Battery would not charge even though it continued to work off the power it was supplying. Tried another battery and had the same problem. My fear was correct in assuming the Left i/o board wa . . .
ユーザのアバター
問題
IO Board broke because pB dropped on the magsafe plug ;; ripped the connecters of the IO Board & blew some circuit.
修理
Part arrived before promised ship date; with the on-line guide replaced the board; reset PRAM and SMC and all is fine again. Very smooth dealing with Ifixit ... kudos' !!
アドバイス
no as difficult . . .
ユーザのアバター
問題
For years I've had a chronic problem with battery charging on a MacBook Pro. The laptop would indicate significant battery life remaining, yet discharge too rapidly and at some point abruptly crash as though all power was removed. Eventually, the battery would not charge at all and the laptop would . . .
ユーザのアバター
問題
My computer was not charging. The power cord would short out due to a bad connection at the Left I/O Board. The cause of the problem started years ago when my daughter decided to chew on the end of the power cord causing corrosion and subsequently shorting between the power cord and Left I/O Board c . . .
さらに表示する
