修理を始めるには
修理する権利
ストア
MacBook Pro 15" (Model A1211) Display Assembly
  • MacBook Pro 15" (Model A1211) Display Assembly
$299.99
$299.99
製品詳細
商品名
商品名
This MacBook Pro 15" (Model A1211) replacement display includes all of the small parts preinstalled in the assembly, saving time and increasing the quality of your repair.
An aging or battered laptop display may suffer a flickering image, dead pixels, or a dim backlight. Surface scratches can further degrade the image and a dented or warped case may pinch the display causing bright spots. Eliminate these flaws with a replacement LCD display assembly. Our displays are individually tested and guaranteed to function perfectly.
以下はパーツの組み立て一覧です。
以下はパーツの組み立て一覧です。
  • 1440 x 900 pixel 15.4" LCD Screen
  • Display Cover
  • Bezel
  • iSight Camera
  • Clutch Hinges
  • Display Inverter
  • Wi-Fi Antenna
  • Display Data Cables
互換性
互換性
  • MacBook Pro 15" A1211
仕様
仕様
Part #:
661-4238, 661-4239
Resolution:
1440x900
Diagonal Size:
15.4"
互換性
MacBook Pro 15" Core 2 Duo Model A1211
A1211 (EMC 2120) 2.16 GHz
A1211 (EMC 2120) 2.33 GHz
修理にまつわるストーリー
ユーザのアバター
問題
Original display had deteriorated. Approx 50 % usable. Replaceing just LCD seemed too tricky, so ordered entire assembly.
修理
Very smoothly and straightforward. Photos were very helpful. A couple of connectors were better identifiable from photo of removed piece.
アドバイス
Read instructions thru to end first. . . .
