修理を始めるには
修理する権利
ストア
Parts Mac MacBook Pro MacBook Pro 15" MacBook Pro 15" Unibody Logic Boards
ストア
Grab a toolkit for your MacBook Pro 15" Unibody model and fix your broken laptop!
iFixit has you covered with parts, tools, and free repair guides. Repair with confidence! All of our replacement parts are tested to rigorous standards and backed by our industry-leading warranty.
モデルを確認されたい方 お持ちのMacのモデル番号を確認する
MacBook Pro 15" Unibody (Mid 2010) 2.4 GHz Logic Board
Replace a 2.4 GHz logic board (motherboard) compatible with the Mid 2010 MacBook Pro 15" Unibody laptop. Fix processing issues like unexpected shutdowns, reboots, or wate...
$199.99
MacBook Pro 15" Unibody (Mid 2010) 2.53 GHz Logic Board
Replace a 2.53 GHz logic board (motherboard) compatible with the Mid 2010 MacBook Pro 15" Unibody laptop. Fix processing issues like unexpected shutdowns, reboots, or wat...
$349.99
MacBook Pro 15" Unibody (Mid 2010) 2.66 GHz Logic Board
Replace a 2.66 GHz logic board (motherboard) compatible with the Mid 2010 MacBook Pro 15" Unibody laptop. Fix processing issues like unexpected shutdowns, reboots, or wat...
$408.99
MacBook Pro 15" Unibody (Late 2008-Early 2009) 2.4 GHz Logic Board
Replace a 2.4 GHz logic board (motherboard) compatible with the Late 2008 to Early 2009 MacBook Pro 15" Unibody laptop. Fix processing issues like unexpected shutdowns, r...
$249.99
MacBook Pro 15" Unibody (Early 2011) 2.0 GHz Logic Board
Replace a 2.0 GHz Core i7 logic board (motherboard) compatible with the Early 2011 MacBook Pro 15" Unibody laptop. Included Ports: Thunderbolt (Mini DisplayPort), 1000Bas...
$358.99
no image
MacBook Pro 15" Unibody (Late 2008) 2.53 GHz Logic Board
Replace a 2.53 GHz logic board (motherboard) compatible with the Late 2008 MacBook Pro 15" Unibody laptop. Included Ports: Mini DisplayPort, 1000BaseT Ethernet, Firewire ...
$349.99
MacBook Pro 15" Unibody (Early 2011) 2.2 GHz Logic Board
Replace a 2.2 GHz logic board (motherboard) compatible with the Early 2011 MacBook Pro 15" Unibody laptop. Included Ports: Thunderbolt (Mini DisplayPort), 1000BaseT Ether...
$408.99
no image
MacBook Pro 15" Unibody (Early 2009) 2.66 GHz Logic Board
Replace a 2.66 GHz logic board (motherboard) compatible with the early 2009 MacBook Pro 15" Unibody laptop. Included Ports: Mini DisplayPort, 1000BaseT Ethernet, Firewire...
$349.99
MacBook Pro 15" Unibody (Early 2011) 2.3 GHz Logic Board
Replace a 2.3 GHz Core i7 logic board (motherboard) compatible with the Early 2011 MacBook Pro 15" Unibody laptop. Included Ports: Thunderbolt (Mini DisplayPort), 1000Bas...
$449.99
no image
MacBook Pro 15" Unibody (Early 2009) 2.93 GHz Logic Board
Replace a 2.93 GHz logic board (motherboard) compatible with the Early 2009 MacBook Pro 15" Unibody laptop. Included Ports: Mini DisplayPort, 1000BaseT Ethernet, Firewire...
$449.99
製品を表示 19の1−10
デバイスの情報
In October of 2008 Apple released the MacBook Pro 15" Unibody with an aluminum case drilled from a single aluminum brick. With the exception of the 2.53 GHz Mid 2009 model, all 15" Unibody models feature 2 graphics cards, one for power saving casual use and one for graphics-intensive processing.
The most common repairs with the MacBook Pro 15" Unibody models are replacing a dead battery, upgrading the hard drive, or upgrading the RAM. Choose a model for more specific information.
Once you've bought your parts and tools, check out iFixit's MacBook Pro 15" Unibody MacBook Pro 15" Unibody Repair for step-by-step instructions on how to make the fix.
