修理を始めるには
修理する権利
ストア
Parts Mac MacBook Pro MacBook Pro 15" MacBook Pro 15" Unibody Case Components
ストア
Grab a toolkit for your MacBook Pro 15" Unibody model and fix your broken laptop!
iFixit has you covered with parts, tools, and free repair guides. Repair with confidence! All of our replacement parts are tested to rigorous standards and backed by our industry-leading warranty.
モデルを確認されたい方 お持ちのMacのモデル番号を確認する
MacBook Pro 15" Unibody (Mid 2009-Mid 2012) Trackpad
Replace a trackpad compatible with the Mid 2009 to Mid 2012 model A1286 MacBook Pro 15 inch Unibody laptop. Part #922-9035, 922-9306, 922-9749.
$59.99
MacBook Pro 15" Unibody (Mid 2010-Mid 2012) Lower Case
Replace a broken or damaged lower case for your Mid 2010 to Mid 2012 MacBook Pro 15" Unibody with this part. This part includes 4 rubber feet.
$74.99
MacBook Pro 15" Unibody (Early 2011-Mid 2012) Airport/Bluetooth Bracket
Replace a bracket that houses the Airport and Bluetooth board compatible with the Early 2011 to Mid 2012 Unibody 15 inch MacBook Pro laptop. Part #076-1380.
$19.99
MacBook Pro 15" Unibody (Late 2008-Early 2009) Trackpad
Replace a trackpad compatible with the Late 2008 or Early 2009 model A1286 MacBook Pro 15" Unibody laptop. Part #922-9008.
$79.99から
MacBook Pro 15" Unibody (Mid 2009) Anti-Glare Upper Case / English Keyboard
Replace an anti-glare upper case, backlit keyboard, and trackpad assembly compatible with the Mid 2009 model A1286 MacBook Pro 15" Unibody laptop.
$299.99から
MacBook Pro 15" Unibody (Late 2008-Early 2009) Upper Case
Replace an Upper Case compatible with the MacBook Pro 15" Unibody A1286 Late 2008 to Early 2009 laptop. Includes the backlit keyboard, trackpad, IR sensor, and battery le...
$59.99
MacBook Pro 15" Unibody (Late 2008-Early 2009) Lower Case
Replace a scratched or dented lower case.
$109.99から
MacBook Pro 15" Unibody (Late 2008-Early 2009) Access Door
Replace a scratched or dented battery access door on your laptop.
$49.99
MacBook Pro 15" Unibody (Mid 2009) Upper Case
Replace an upper case, backlit keyboard, and battery level indicator assembly compatible with the Mid 2009 model A1286 MacBook Pro 15 inch Unibody laptop.
$14.99から
MacBook Pro 15" Unibody (Late 2008-Early 2009) Mid Wall
Replace the center bracing inside your machine.
$19.99
製品を表示 15の1−10
デバイスの情報
In October of 2008 Apple released the MacBook Pro 15" Unibody with an aluminum case drilled from a single aluminum brick. With the exception of the 2.53 GHz Mid 2009 model, all 15" Unibody models feature 2 graphics cards, one for power saving casual use and one for graphics-intensive processing.
The most common repairs with the MacBook Pro 15" Unibody models are replacing a dead battery, upgrading the hard drive, or upgrading the RAM. Choose a model for more specific information.
Once you've bought your parts and tools, check out iFixit's MacBook Pro 15" Unibody MacBook Pro 15" Unibody Repair for step-by-step instructions on how to make the fix.
