Parts Mac MacBook Pro MacBook Pro 15" MacBook Pro 15" Retina MacBook Pro 15" Retina Late 2013 Logic Boards
ストア
Grab a toolkit for your MacBook Pro 15" Retina Late 2013 model and fix your broken laptop!
iFixit has you covered with parts, tools, and free repair guides. Repair with confidence! All of our replacement parts are tested to rigorous standards and backed by our industry-leading warranty.
モデルを確認されたい方 お持ちのMacのモデル番号を確認する
MacBook Pro 15" Retina (Mid 2014, Dual Graphics) 2.5 GHz Logic Board
Replace a 2.5 GHz Core i7 logic board (motherboard) compatible with the mid 2014 Dual Graphics model MacBook Pro 15" Retina laptop. Included Ports: 2 Thunderbolt (Mini Di...
$449.99
MacBook Pro 15" Retina (Late 2013, Integrated Graphics) 2.0 GHz Logic Board
Replace a 2.0 GHz Core i7 logic board (motherboard) compatible with the Late 2013 Integrated Graphics model MacBook Pro 15" Retina laptop. Includes RAM. Included Ports: 2...
$299.99から
MacBook Pro 15" Retina (Mid 2014, Integrated Graphics) 2.8 GHz Logic Board / 16  GB
Replace a 2.8 GHz Core i7 logic board (motherboard) compatible with the Mid 2014 Integrated Graphics MacBook Pro 15" Retina laptop. Included Ports: 2 Thunderbolt (Mini Di...
$699.99
no image
MacBook Pro 15" Retina (Mid 2014, Dual Graphics) 2.8 GHz Logic Board
Replace a 2.8 GHz Core i7 logic board (motherboard) compatible with the Mid 2014 Dual Graphics model MacBook Pro 15" Retina laptop. Fix processing issues like unexpected ...
$499.99
MacBook Pro 15" Retina (Late 2013, Integrated Graphics) 2.6 GHz Logic Board
Replace a 2.6 GHz Core i7 logic board (motherboard) compatible with the Late 2013 Integrated Graphics MacBook Pro 15" Retina laptop. Includes RAM. Included Ports: 2 Thund...
$399.99
MacBook Pro 15" Retina (Late 2013, Dual Graphics) 2.3 GHz Logic Board
Replace a 2.3 GHz Core i7 logic board (motherboard) compatible with the Late 2013 Dual Graphics model MacBook Pro 15" Retina laptop. Included Ports: 2 Thunderbolt (Mini D...
$429.99
MacBook Pro 15" Retina (Late 2013, Dual Graphics) 2.6 GHz Logic Board
Replace a 2.6 GHz Core i7 logic board (motherboard) compatible with the Late 2013 Dual Graphics model MacBook Pro 15" Retina laptop. Included Ports: 2 Thunderbolt (Mini D...
$899.99
MacBook Pro 15" Retina (Mid 2014, Integrated Graphics) 2.2 GHz Logic Board / 16  GB
Replace a 2.2 GHz Core i7 logic board (motherboard) compatible with the MacBook Pro 15" Retina (Mid 2014, Integrated Graphics) laptop. Fix processing issues like unexpect...
$379.99
MacBook Pro 15" Retina (Mid 2014, Integrated Graphics) 2.5 GHz Logic Board / 16  GB
Replace a 2.5 GHz Core i7 logic board (motherboard) compatible with the Mid 2014 Integrated Graphics MacBook Pro 15" Retina laptop. Fix processing issues like unexpected ...
$649.99
no image
MacBook Pro 15" Retina (Late 2013, Integrated Graphics) 2.3 GHz Logic Board
Replace a 2.3 GHz Core i7 logic board (motherboard) compatible with the Late 2013 Integrated Graphics model MacBook Pro 15" Retina laptop. Includes RAM. Included Ports: 2...
$549.99から
製品を表示 10の1−10
デバイスの情報
On October 22, 2013 Apple introduced a new 15" MacBook Pro with Retina display that is externally identical to the "Early 2013" model by dimensions, weight, and 2880x1800 display resolution. Internally, the Late 2013 model has a faster and more efficient processor architecture, entry level models have a single integrated graphics (IG) processor, and higher-end models offer a dual graphics (DG) processor. The Late 2013 model has two USB 3.0 ports, an HDMI port, an SDXC card slot, a MagSafe 2 port, two Thunderbolt 2 ports, Bluetooth 4.0, and 802.11ac Wi-Fi. Like the Early 2013 model the Late 2013 does not have Ethernet or Firewire ports, although adapters are available.
The most common repairs with the 15" MacBook Pro Retina Late 2013 laptops are replacing a dead battery, replacing a malfunctioning left or right fan, or a damaged display assembly.
The battery in a MacBook Pro 15" Retina Late 2013 is adhered to the inside of the upper case. Our battery repair kits include the needed adhesive.
The MacBook Pro 15" Retina Display models require a P5 Pentalobe Screwdriver to remove the lower case to begin any internal repairs. Our battery kits include all the needed tools.
Once you've bought your parts and tools, check out iFixit's MacBook Pro 15" Retina Display Late 2013 repair guides for step-by-step instructions on how to make the fix.
The MacBook Pro 15" Retina Display Late 2013 earned a 1 out of 10 in iFixit's repairability assessment.
