MacBook Pro 15" Display Components
Grab a toolkit for your MacBook Pro 15" model and bring your laptop back to life!
iFixit has you covered with parts, tools, and free repair guides. Repair with confidence! All of our replacement parts are tested to rigorous standards and backed by our industry-leading warranty.
お持ちの MacBook Pro 15" モデルを選択:
MacBook Pro 15"で使用されているパーツ:
MacBook Pro 15" (Models A1226/A1260) LED Driver Board
LED Driver Board controls the LED backlight.
MacBook Pro 15" (Models A1226/A1260) Inverter/iSight Cable
MacBook Pro 15" (Model A1260) AirPort Antenna Cables
Replace the antenna cables and the assembly that rests inside the antenna cover compatible with the A1260 model Early 2008 15 inch MacBook Pro laptop.
MacBook Pro 15" Unibody (Late 2008-Early 2009) AirPort/iSight Cable
Replace a damaged or missing cable connecting the iSight camera and the Airport card to the logic board in a Late 2008 or Early 2009 model 15" Unibody MacBook Pro.
MacBook Pro 15" (Models A1211/A1226/A1260) Antenna Cover
Replace an antenna cover that houses the AirPort antenna cable assembly within the clutch cover compatible with the model A1211, A1226, A1260 15 inch MacBook Pro laptop.
MacBook Pro 15" (Models A1150/A1211) Display Data Cable
A damaged display data cable can cause video defects
MacBook Pro 15" (Models A1226/A1260) Clutch Cover
Houses the hinges and airport antenna assembly.
MacBook Pro 15" (Model A1150) Inverter/iSight Cable
MacBook Pro 15" (Models A1226/A1260) Front Display Bezel
Replace a damaged bezel without the cost of a new LCD
MacBook Pro 15" (Models A1150/A1211) Display Inverter
A bad inverter board can cause a dead backlight
デバイスの情報
Catering to the working professional, the MacBook Pro is aptly named. With powerful processor and graphics capabilities, these Apple machines are great for either the professional or aspiring creative genius.
Please select your version above for parts and support!
