問題
Coating was coming off my retina screen.
修理
The web site instructions were spot on! The repair was easy and fun to do. I had 0 issues. Thanks!!!
アドバイス
As long as you follow the directions, it's an easy repair. Took me less than 30 minutes
この製品はお住まいの国ではお買い求めできません。
アイテムコード: IF123-011-4
製品詳細
商品名
商品名
This Late 2012 to Early 2013 MacBook Pro 13" Retina replacement display includes all of the small parts preinstalled in the assembly, saving time and increasing the quality of your repair.
An aging or battered laptop display may suffer a flickering image, dead pixels, or a dim backlight. Surface scratches can further degrade the image and a dented or warped case may pinch the display causing bright spots. Eliminate these flaws with a replacement LCD display assembly. Our displays are individually tested and guaranteed to function perfectly.
以下はパーツの組み立て一覧です。
以下はパーツの組み立て一覧です。
商品名
商品名
以下はパーツの組み立て一覧です。
以下はパーツの組み立て一覧です。
互換性
互換性
仕様
仕様
仕様
仕様
互換性
修理にまつわるストーリー
Cracked Retina display
It couldn't have been easier -- in fact it was actually fun. The tools were perfectly matched for each task and the instructions were very easy to follow.
Don't be intimidated
Crack in display
Very good, the only difficult part was to replace the new display and connect it with the first 2 screws.
I carelessly put a small crack in my previous screen and after getting an estimate from a shifty guy at the Apple store I would have been better off replacing the whole Macbook. I'm in college and I need to save the money.
The process was smooth and easy with excellent steps and pictures to help bulster confidence. This is the first time I've really opened up a piece of technology and I was initially very nervous. Now I am interested in doing it for other people for a significantly lower cost than your typical store.
Do your research with pricing on repairs, but if you're comfortable with reading directions, this will be a cakewalk.
The process was smooth and easy with excellent steps and pictures to help buls . . .
Cracked display.
Smoothly.
Must have proper screwdrivers (Torx 2, 5, 6, 7, and 8, I believe).
My old retina display was dying. I had a streak of dying pixels down the left side of my monitor
The replacement was simple thanks to IFIXIT! Before even cracking open the case I knew which tools I needed, the task at hand, and the basic time I would need to allot for the job. I swapped out my lid assembly with ease and no surprises and my Macbook is back up and running as good as new.
Don't be that person that just dives in to your repair without a little research. Apple is infamous for coming up with odd sized hardware, weird processes to get to where you need to go, and ultra delicate parts. Watch the video's IFIXIT provides, read the instructions and you will be back to work in no time!
The replacement was simple thanks to IFIXIT! Before even cracking open the case I knew which tools I needed, the task at hand, and the basic time I would need to allot for the job. I swapped out my lid as . . .
The screen was damaged when the laptop was dropped
Screen replaced
I had someone experienced in repairing my laptop complete the repair. Very satisfied and happy with the outcome.
さらに表示する
表示を隠す
