製品詳細
商品名
This replacement battery fix kit includes includes all the parts, tools, and adhesive you need to bring your dead laptop back to life!
- 100% factory tested.
- Tested and guaranteed to have no cycles on the cell and to have a capacity greater than 6270 mAh.
- Spot tested by iFixit staff in San Luis Obispo, CA to ensure consistency of quality and capacity.
- Assembled using a high quality chipset from Texas Instruments.
Battery degradation is an inevitable part of your MacBook Pro's lifespan, extend it with this new replacement battery compatible with MacBook Pro 13" Retina (Late 2012-Early 2013). Factory-installed MacBook Pro 13" Retina (Late 2012-Early 2013) batteries are rated to last 1,000 cycles. If your laptop won't turn on, turns off suddenly, has a "service battery" warning, or simply won't hold a charge, this replacement battery may be what you need to fix it. Our aftermarket replacement batteries lead the industry in quality and reliability, so you know you're getting the best money can buy.
キットの中身
- New Replacement Battery compatible with a MacBook Pro 13" Retina (Late 2012/Early 2013) laptop
- Installation Adhesive
- iFixit Adhesive Remover
- Safety Glasses
- Nitrile Gloves (2)
- Berkshire PRO Wipe 880
- Spudger
- iFixit Opening Tool
- iFixit Opening Picks (Set of 6)
- Plastic Cards
- Angled Tweezers
- Precision Bit Driver
- 4 mm Precision Bits:
- Pentalobe P5
- Torx T5
- Torx Security TR6
互換性
- MacBook Pro 13" Retina A1425 Late 2012 to Early 2013
仕様
互換性
交換ガイド
MacBook Pro 13インチRetinaディスプレイ(2013年初期)の交換
難易度:
難しい
MacBook Pro 13インチ Retina Display Early 2013 上部ケースの交換
難易度:
普通
MacBook Pro 13" Retina Display Early 2013 トラックパッドの交換
難易度:
普通
MacBook Pro 13インチ Retina Display Late 2012 バッテリーの交換
難易度:
難しい
MacBook Pro 13インチ Retina Display Late 2012 上部ケースの交換
難易度:
難しい
MacBook Pro 13インチ Retina Display Late 2012 トラックパッドの交換
難易度:
普通
カスタマーレビュー
