MacBook Pro 13" Unibody Early 2011 Case Components
Grab a toolkit for your MacBook Pro 13" Unibody Early 2011 model and fix a broken laptop!
iFixit has you covered with parts, tools, and free repair guides. Repair with confidence! All of our replacement parts are tested to rigorous standards and backed by our industry-leading warranty.
MacBook Pro 13" Unibody Early 2011で使用されているパーツ:
MacBook Pro 13" Unibody (Mid 2009-Mid 2012) Trackpad
Replace a scratched or malfunctioning trackpad in your Mid 2009 to Mid 2012 13” Unibody MacBook Pro model A1278 laptop. Part #922-9063, 922-9525, 922-9773.
MacBook Pro 13" Unibody (Early 2011-Mid 2012) Upper Case
Replace an upper case assembly compatible with the model A1278 Early 2011 to Mid 2012 MacBook Pro 13 inch Unibody laptop.
MacBook Pro 13" Unibody Lower Case
Replace a scratched or bent lower case panel on your laptop.
MacBook Pro 13" Unibody (Early 2011-Mid 2012) Airport/Bluetooth Bracket
Replace the bracket that houses the Airport/Bluetooth board compatible with the Early 2011 to Mid 2012 A1278 Unibody 13 inch MacBook Pro laptop. Part #076-1381.
MacBook Pro Unibody (Mid 2009-Mid 2012) Trackpad Mounting Screws
Replacement screws and springs for mounting the trackpad in the upper case assembly of your mid 2009 to mid 2012 13" and 15" MacBook Pro Unibody laptop.
デバイスの情報
In February 2011, Apple refreshed the 13" MacBook Pro line by changing to the Intel HD Graphics 3000, increasing VRAM to 384 MB, and upgrading to Core i5 and Core i7 processors with PC3-10600 RAM. The Mini DisplayPort was also replaced (but still backwards compatible) with the new Thunderbolt standard allowing 10 Gbps transfer speeds in both directions.
The most common repairs with the MacBook Pro 13" Unibody for Early 2011 are replacing a dead battery or upgrading the hard drive or RAM. The MacBook Pro 13" Unibody (Early 2011) Memory Maxxer RAM Upgrade Kit includes all the parts and tools you need to upgrade to 16 GB of RAM.
The MacBook Pro 13" Unibody for Early 2011 requires a Tri-point Y0 Screwdriver to remove the battery. The battery kit includes all the needed tools.
Once you've bought your parts and tools, check out iFixit's MacBook Pro 13" Unibody for Early 2011 repair guides for step-by-step instructions on how to make the fix.
