修理を始めるには
修理する権利
パーツ&ツール
Parts Mac MacBook Pro MacBook Pro 13" MacBook Pro 13" Retina MacBook Pro 13" Touch Bar Mid 2018 SSD Enclosures
ストア
Grab a toolkit for your MacBook Pro 13" Touch Bar Mid 2018 model and fix your broken laptop!
iFixit has you covered with parts, tools, and free repair guides. Repair with confidence! All of our replacement parts are tested to rigorous standards and backed by our industry-leading warranty.
モデルを確認されたい方 お持ちのMacのモデル番号を確認する
Arctic Silver Thermal Paste
Forms a continuous, heat conductive layer between a processor and its heat sink. A new layer of thermal paste keeps your processor from overheating. 3.5 grams
$8.99
Arctic Silver ArctiClean
Two part cleaner dissolves old thermal paste on heat sinks and processors. One 30 ml bottle of thermal material remover and one 30 ml bottle of thermal surface purifier.
$7.99
MacBook Pro 13" Retina (Touch Bar, Late 2016-2019) Antenna Bar
Replace a damaged or malfunctioning antenna.
$24.99から
MacBook Pro 13" Retina (Touch Bar, Late 2016-2019) Right Small Speaker
Replace a damaged or malfunctioning high frequency tweeter speaker for the right side of a Late 2016 to 2019 MacBook Pro 13" with Touch Bar.
$19.99から
MacBook Pro 13" Retina (Touch Bar, Late 2016-2019) Left Small Speaker
Replace a damaged or malfunctioning high frequency tweeter speaker.
$19.99から
MacBook Pro 13"/15" Retina (Touch Bar, Mid 2018) Keyboard
Replace a damaged, dirty, corroded, or malfunctioning keyboard.
$149.99
MacBook Pro 13" Retina (Touch Bar, Late 2016-2019) Lower Case / Silver / New
Replace a scratched or dented lower case compatible with a 2016 to 2019 model 13" MacBook Pro with Retina Display and Touch Bar.
$29.99から
MacBook Pro 13" Retina (Mid 2018-2019) Microphone / New
Replace a damaged or torn microphone cable or a malfunctioning microphone compatible with a 2018 to 2019 model 13" MacBook Pro with Retina Display.
$14.99から
MacBook Pro 13" Retina (Touch Bar, Late 2016-2019) Headphone Jack Bracket
Replace a bent or missing metal bracket that secures the headphone jack cable connector to the logic board in a 2016 to 2019 model 13" MacBook Pro with Retina Display and...
$3.99
MacBook Pro 13" Retina (Mid 2018-2019) Headphone Jack
Replace a damaged or corroded the 3.5 mm audio jack compatible with a 2018 or 2019 model 13" MacBook Pro with Retina Display.
$23.99から
製品を表示 37の1−10
デバイスの情報
Released in July 2018, this 13" Macbook Pro features Coffee Lake processors up to 2.7 GHz Core i7 with Turbo Boost up to 4.5 GHz. Model A1989.
The most common repairs with the 13" 2018 model MacBook Pro with Retina Display and Touch Bar laptops are replacing a dead battery or a damaged display assembly.
The battery in a MacBook Pro 13" Retina and Touch Bar 2018 is adhered to the inside of the upper case. Our batteries include the needed adhesive.
The MacBook Pro 13" Retina Display models require a P5 Pentalobe Screwdriver to remove the lower case to begin any internal repairs.
Once you've bought your parts and tools, check out iFixit's MacBook Pro 13" Retina Display and Touch Bar 2018 repair guides for step-by-step instructions on how to make the fix.
The MacBook Pro 13" Retina Display and Touch Bar 2018 earned a 1 out of 10 in iFixit's repairability assessment.
