MacBook Pro 13" Touch Bar Mid 2018 Logic Boards
Grab a toolkit for your MacBook Pro 13" Touch Bar Mid 2018 model and fix your broken laptop!
iFixit has you covered with parts, tools, and free repair guides. Repair with confidence! All of our replacement parts are tested to rigorous standards and backed by our industry-leading warranty.
MacBook Pro 13" Touch Bar Mid 2018で使用されているパーツ:
MacBook Pro 13" Retina (Mid 2018) 2.3 GHz Logic Board with Paired Touch ID Sensor
Replace a 2.3 GHz Core i5 logic board (motherboard) compatible with the Mid 2018 MacBook Pro 13" Retina laptop. Includes RAM, SSD, and Touch ID sensor. Fix processing iss...
MacBook Pro 13" Retina (Mid 2018) 2.7 GHz Logic Board with Paired Touch ID Sensor
Replace a damaged or malfunctioning 2.7 GHz Core i7 Logic Board. The Touch ID sensor is paired to the logic board and is included.
デバイスの情報
Released in July 2018, this 13" Macbook Pro features Coffee Lake processors up to 2.7 GHz Core i7 with Turbo Boost up to 4.5 GHz. Model A1989.
The most common repairs with the 13" 2018 model MacBook Pro with Retina Display and Touch Bar laptops are replacing a dead battery or a damaged display assembly.
The battery in a MacBook Pro 13" Retina and Touch Bar 2018 is adhered to the inside of the upper case. Our batteries include the needed adhesive.
The MacBook Pro 13" Retina Display models require a P5 Pentalobe Screwdriver to remove the lower case to begin any internal repairs.
Once you've bought your parts and tools, check out iFixit's MacBook Pro 13" Retina Display and Touch Bar 2018 repair guides for step-by-step instructions on how to make the fix.
The MacBook Pro 13" Retina Display and Touch Bar 2018 earned a 1 out of 10 in iFixit's repairability assessment.
