パーツ Mac MacBook Pro 13" Touch Bar 2019 Hard Drive Enclosures
ストア
Grab a MacBook Pro 13" Touch Bar 2019 Fix Kit and bring your laptop back to life!
iFixit has you covered with parts, tools, and free repair guides. Repair with confidence! All of our replacement parts are tested to rigorous standards and backed by our industry-leading warranty.
モデルを確認されたい方 お持ちのMacのモデル番号を確認する
Arctic Silver Thermal Paste
Forms a continuous, heat conductive layer between a processor and its heat sink. A new layer of thermal paste keeps your processor from overheating. 3.5 grams
$8.99
Arctic Silver ArctiClean
Two part cleaner dissolves old thermal paste on heat sinks and processors. One 30 ml bottle of thermal material remover and one 30 ml bottle of thermal surface purifier.
$7.99
MacBook Pro 13" Retina (Late 2016-2019) Display Assembly / A-Stock / Silver
The display assembly includes the Retina LCD screen, display cover, bezel, FaceTime HD Camera, clutch hinges, display daughter board, and cable spring mechanism. Compatib...
$469.99から
MacBook Pro 13" Retina (Late 2016-2019) Trackpad / New / Silver
Replace a scratched or malfunctioning trackpad compatible with a Late 2016 to 2019 MacBook Pro 13" with Retina Display, Touch Bar or Function Keys model.
$49.99から
MacBook Pro 13" Retina (Touch Bar, Late 2016-2019) Lower Case Screw Set / Silver
Replace the external screws securing the lower case.
$19.99
MacBook Pro 13" Retina (2019) 2.4 GHz Logic Board / 8 GB / 256 GB
Replace a damaged or malfunctioning 2.4 GHz Core i5 Motherboard. The Touch ID sensor is paired to the logic board and is included.
$799.99
MacBook Pro Retina (A1989 & A1990 Mid 2018-2019) USB-C Board
Replace one of the thunderbolt connector boards from the left or right side of your laptop.
$34.99
MacBook Pro 13" Retina (Touch Bar, Late 2016-2019) Lower Case / Silver / New
Replace a scratched or dented lower case compatible with a 2016 to 2019 model 13" MacBook Pro with Retina Display and Touch Bar.
$29.99から
MacBook Pro 13" Retina (Touch Bar, Late 2016-2019) Trackpad Cable / New
Replace the flex cable that connects the trackpad to the logic board.
$24.99から
MacBook Pro 13" Retina (Touch Bar, Late 2016-2019) Right Fan / Used
Replace a defective or noisy fan compatible with a 2016 to 2019 model 13" MacBook Pro with Retina Display and Touch Bar.
$49.99から
製品を表示 32の1−10
デバイスの情報
Introduced in May 2019, this 13" Macbook Pro features Coffee Lake processors up to 2.8 GHz Core i7 with Turbo Boost up to 4.7 GHz. Model A1989.
The most common repairs with the 13" 2019 model MacBook Pro with Retina Display and Touch Bar laptops are replacing a dead battery or a damaged display assembly.
The battery in a MacBook Pro 13" Retina and Touch Bar 2019 is adhered to the inside of the upper case. Our batteries include the needed adhesive.
The MacBook Pro 13" Retina Display models require a P5 Pentalobe Screwdriver to remove the lower case to begin any internal repairs.
Once you've bought your parts and tools, check out iFixit's MacBook Pro 13" Retina Display and Touch Bar 2019 repair guides for step-by-step instructions on how to make the fix.
