パーツ Mac MacBook Pro 13" Function Keys Mid 2017 Hard Drive Brackets
ストア
モデルを確認されたい方 お持ちのMacのモデル番号を確認する
Arctic Silver Thermal Paste
Forms a continuous, heat conductive layer between a processor and its heat sink. A new layer of thermal paste keeps your processor from overheating. 3.5 grams
$8.99
Arctic Silver ArctiClean
Two part cleaner dissolves old thermal paste on heat sinks and processors. One 30 ml bottle of thermal material remover and one 30 ml bottle of thermal surface purifier.
$7.99
MacBook Pro 13" Retina (Function Keys, Late 2016-2017) Battery / Fix Kit
Replacement battery compatible with MacBook Pro 13" Retina (Function Keys, Late 2016/2017).
$139.99から
MacBook Pro 13" Retina (Late 2016-2019) Display Assembly / A-Stock / Silver
The display assembly includes the Retina LCD screen, display cover, bezel, FaceTime HD Camera, clutch hinges, display daughter board, and cable spring mechanism. Compatib...
$599.99から
MacBook Pro 13" Retina (Function Keys, Late 2016-2017) Display Cable
Replace the short flex cable that connects the display daughter board to the logic board.
$24.99
MacBook Pro Retina (2016-2019) Display Backlight Cables
Replace the two flex cables connecting the display backlight to the display daughter baord.
$9.99
MacBook Pro 13" Retina (Function Keys, Late 2016-2017) Fan
Replace a malfunctioning or noisy fan.
$29.99から
MacBook Pro 13" Retina (Function Keys, Late 2016-2017) Lower Case / Silver / New
Replace a scratched or dented lower case.
$29.99から
MacBook Pro 13" Retina (Late 2016-2019) Trackpad / New / Silver
Replace a scratched or malfunctioning trackpad compatible with a Late 2016 to 2019 MacBook Pro 13" with Retina Display, Touch Bar or Function Keys model.
$49.99から
MacBook Pro 13" Retina (Function Keys, Late 2016-2017) Keyboard
Replace a damaged, dirty, corroded, or malfunctioning keyboard.
$149.99
製品を表示 36の1−10
デバイスの情報
Released in June 2017 with Apple model number A1708 / EMC 3164, this entry-level MacBook Pro retains its traditional function keys (as opposed to the OLED Touch Bar). This model packs an Intel Core i5 or i7 processor and two Thunderbolt 3 ports.
The most common repairs with the 13" 2017 model MacBook Pro with Retina Display and Function Keys laptops are replacing a dead battery or a damaged display assembly.
The battery in a MacBook Pro 13" Retina and Function Keys 2017 is adhered to the inside of the upper case. Our battery repair kits include the needed adhesive.
The MacBook Pro 13" Retina Display models require a P5 Pentalobe Screwdriver to remove the lower case to begin any internal repairs. Our battery kits include all the needed tools.
Once you've bought your parts and tools, check out iFixit's MacBook Pro 13" Retina Display and Function Keys 2017 repair guides for step-by-step instructions on how to make the fix.
