修理を始めるには
修理する権利
パーツ&ツール
MacBook Core Duo/Santa Rosa/Penryn LCD Mounts
  • MacBook Core Duo/Santa Rosa/Penryn LCD Mounts
$7.99
$7.99
ご希望の商品が再入荷しましたらお知らせします。
Nintendo Switch 修理キット
ゲームを再開するための、早くて簡単な修理キット
Switch 修理キットページへ
Switch 修理キットページへ
製品詳細
概要
概要
LCD hanging on by a thread?
Lock it down with some LCD mounts! Includes LCD mounts and airport antenna cables.
This part works with model A1181 MacBooks with 2 antenna connectors. If your MacBook has 3 antenna connectors you need the Core 2 Duo hinge mounts.
互換性
互換性
  • 1.83 or 2 GHz Core Duo MacBooks
  • 2.0 (Santa Rosa) or 2.2 GHz Core 2 Duo MacBooks
  • 2.1 or 2.4 GHz Core 2 Duo MacBooks
  • 2.0 GHz (Early 2009) Core 2 Duo MacBooks
  • 2.13 GHz (Mid 2009) Core 2 Duo MacBooks
互換性
MacBook Core 2 Duo
A1181 (EMC 2121) 2 GHz (Santa Rosa)
A1181 (EMC 2200) 2.2 GHz (Santa Rosa)
A1181 (EMC 2242) 2.1 GHz (Penryn)
A1181 (EMC 2242) 2.4 GHz (Penryn)
A1181 (EMC 2300) 2 GHz (Early 2009)
A1181 (EMC 2330) 2.13 GHz (Mid 2009)
MacBook Core Duo
A1181 (EMC 2092) 1.83 GHz
A1181 (EMC 2092) 2 GHz
修理にまつわるストーリー
ユーザのアバター
問題
WIFI antenna wire was broken where it passes through the hinge of the display.
修理
The online guide was helpful - take the time to go slow and follow each step.
アドバイス
Set aside enough time to do the repair right - keep track of where the screws from each step go so you don't get them mixed up later.
ユーザのアバター
問題
My airport would only work if the computer did not move after startup. If moved the airport would turn off and could not be turned back on without restarting. After researching the problem I deduced that it was probable that the antenna wires had been pinched/worn from the screen opening and closing . . .
