修理を始めるには
修理する権利
ストア
MacBook Air (Original) Fan and Heat Sink
  • MacBook Air (Original) Fan and Heat Sink
$39.99
$39.99
製品詳細
商品名
商品名
An aging fan may become noisy and inefficient or simply fail and stop spinning, leaving your model A1237 MacBook Air to overheat and eventually damaging your processors. Replace a defective fan and heat sink to fix overheating problems or to keep your laptop running quietly.
以下はパーツの組み立て一覧です。
以下はパーツの組み立て一覧です。
  • Fan
  • Attached Heat Sink
互換性
互換性
  • 1.6 or 1.8 GHz Original MacBook Airs
仕様
仕様
Part #:
922-8316
ビデオをインストール
互換性
MacBook Air Models A1237 and A1304
EMC 2142 1.6 GHz (Original)
EMC 2142 1.8 GHz (Original)
修理にまつわるストーリー
ユーザのアバター
問題
The fan was making a whistle noise... and the CPU was too hot for MBA to work normally.
修理
Changed the fan. Cleaned the inside of the laptop from dust…
アドバイス
Clean the inside at least twice a year…
ユーザのアバター
問題
Existing fan was loud
修理
The repair went according to instructions. I like how all the different screws are identified. Made it really easy for reinstallation.
アドバイス
Ifixit shows instructions on how to remove the fan from the heatsink but does not offer the option of buy the fan only. I had to buy the heatsink . . .
ユーザのアバター
問題
The machine began to run a little hot with excessive fan activity. Eventually no fan, just a faint clicking sound and rising temperatures, which I diagnosed from various blogs as fan failure.
I hadn't checked the heatsink vs processor temperatures so couldn't confirm the state of the heat sink / . . .
ユーザのアバター
問題
So, my original MacBook Air's fan started making a *horrible* very, un-Apple-like screeching sound. I added some lubrication and that helped a little, but in the end it appeared the fan unit itself had just worn out after working at thousands of RPMs for many hours thru the years.
修理
The repair took abo . . .
さらに表示する
