修理を始めるには
修理する権利
パーツ&ツール
Parts Mac MacBook Air MacBook Air 11" MacBook Air 11" Early 2014 Heat Sinks
ストア
Grab a toolkit for your MacBook Air 11" Early 2014 model and fix your broken laptop!
iFixit has you covered with parts, tools, and free repair guides. Repair with confidence! All of our replacement parts are tested to rigorous standards and backed by our industry-leading warranty.
モデルを確認されたい方 お持ちのMacのモデル番号を確認する
Arctic Silver Thermal Paste
Forms a continuous, heat conductive layer between a processor and its heat sink. A new layer of thermal paste keeps your processor from overheating. 3.5 grams
$8.99
Arctic Silver ArctiClean
Two part cleaner dissolves old thermal paste on heat sinks and processors. One 30 ml bottle of thermal material remover and one 30 ml bottle of thermal surface purifier.
$7.99
MacBook Air 11" (Mid 2011-Early 2015) Replacement Battery / Fix Kit
Replace a 5100 mAh battery compatible with the MacBook Air 11" Mid 2011 to Early 2015 A1370 and A1465 model laptop. 38.75 Watt Hours (Wh). 7.6 Volts (V). Battery model A1...
$79.99から
OWC Aura Pro X2 SSD
OWC Aura Pro X2 SSD
Replace or upgrade the PCIe solid-state drive in a variety of Macs.
$139.99から
MacBook Air Plastic Feet
Replace the black plastic feet on the lower case of your laptop. These feet are compatible with most 11" or 13" MacBook Air laptops.
2.5" Hard Drive Enclosure with USB 3.0 Cable
Turn any SATA 2.5" laptop hard drive into an external storage drive with this part.
$12.99
MacBook Air 11" (Mid 2013-Early 2015) I/O Board
Replace a damaged or corroded I/O board for your Mid 2013 to Early 2015 MacBook Air 11" and fix problems with charging, audio, and data connections. This assembly include...
$49.99
MacBook Air 11" (Mid 2011-Early 2015) Keyboard
Replace a damaged, dirty, corroded, or malfunctioning keyboard compatible with a model A1370 11" MacBook Air from mid 2011 or a model A1465 11" MacBook Air from mid 2012 ...
$19.99
OWC Envoy Pro External SSD Enclosure (Mid 2013 to Mid 2015 Macs)
Make your factory installed Apple PCIe SSD into an external SSD drive. Transfer data to a newly installed internal SSD or keep the original drive as added external storag...
$99.99
MacBook Air (Mid 2013-2017) AirPort/Bluetooth Board
Fix wireless connectivity issues by replacing the 802.11ac AirPort wireless / Bluetooth 4.0 internal card in your Mid 2013 to 2017 MacBook Air.
$59.99
製品を表示 29の1−10
デバイスの情報
Released on April 29, 2014, this 11" MacBook Air is much the same as its predecessor externally and internally save for a faster processor and longer reported battery life. Includes one "Thunderbolt" port, two USB 3.0 ports, 802.11ac Wi-Fi and Bluetooth 4.0.
