パーツ Mac MacBook 13" Core Duo Hard Drives SATA
ストア
モデルを確認されたい方 お持ちのMacのモデル番号を確認する
Arctic Silver Thermal Paste
Forms a continuous, heat conductive layer between a processor and its heat sink. A new layer of thermal paste keeps your processor from overheating. 3.5 grams
$8.99
Arctic Silver ArctiClean
Two part cleaner dissolves old thermal paste on heat sinks and processors. One 30 ml bottle of thermal material remover and one 30 ml bottle of thermal surface purifier.
$7.99
MacBook and MacBook Pro (Non-Retina) SSD Upgrade Bundle
Upgrade the storage and improve boot time and read/write speed in your MacBook and MacBook Pro (Non-Retina) with this SSD upgrade bundle.
$114.99から
500 GB SSD / Part Only
500 GB SSD
SATA 6.0 Gb/s interface for Intel Macs / Solid State Drive / 2.5" wide x 7mm tall / 525 GB Unformatted
$139.99から
1 TB SSD Hybrid 2.5" Hard Drive / Part Only
SATA 6.0 Gb/s interface for Intel Macs / Solid State Drive Hybrid, 5400 RPM / 2.5" wide x 9.5mm tall / 1 TB Unformatted
$84.99から
Silicone 2.5" Hard Drive Enclosure with USB 2.0 Cable
Turn any SATA 2.5" laptop hard drive into an external storage drive with this part.
$9.99
250 GB SSD / Part Only
250 GB SSD
SATA 6.0 Gb/s interface for Intel Macs / Solid State Drive / 2.5" wide x 7mm tall / 275 GB Unformatted
$94.99から
MacBook 13.3" LCD Panel
Replace your cracked or damaged MacBook LCD with this part. This part is compatible with all 13.3" (1280x800) MacBooks (excluding MacBook Unibody and MacBook Air).
$49.99
1 TB SSD / Part Only
1 TB SSD
SATA 6.0 Gb/s interface for Intel Macs / Solid State Drive / 2.5" wide x 7mm tall / 1050 GB Unformatted
$249.99から
Universal Drive Adapter
Turn your current hard drive into an external drive with this part.
$24.99
製品を表示 67の1−10
デバイスの情報
The MacBook 13" Core Duo can be easily upgraded to a total of 2 GB of memory using two 1 GB RAM chips, and a 500 GB 7200 RPM SATA hard drive will give you plenty of storage. You can upgrade to the Santa Rosa/Penryn Upper Case, featuring a new keyboard layout (including iTunes controls)! The 8x SuperDrive is the fastest optical drive for this model and will make creating DVDs a whiz. Have you ever been caught sleeping while waiting for your file to transfer over slow wireless network? We can wipe away that unnecessary snooze-fest with the Airport Extreme 802.11n Card upgrade.
There is one main variation within this model. The heat sink thermal sensors may have three-wall or four-wall connectors. This affects the heat sink and logic board. See photos and part descriptions on the three-wall or four-wall heat sinks for information on determining which version you have.
Check out our MacBook troubleshooting page for help in diagnosing your machine!
Select your category below or browse all compatible parts to find what you need to fix your laptop!
