修理を始めるには
修理する権利
ストア
1 TB SSD Hybrid 3.5" Hard Drive
  • 1 TB SSD Hybrid 3.5" Hard Drive / New / Part Only
$109.99
$109.99
製品詳細
商品名
商品名
Replace or upgrade the hard drive in your compatible iMac with this part.
互換性
互換性
  • iMac G5 17" EMC 2055
  • iMac G5 20"
  • All 21.5" and 27" pre 2011 Intel iMacs
  • All G5 Power Macs
仕様
仕様
Model #:
ST1000DX002
Cache:
64 MB
Drive Capacity:
1 TB Unformatted
Speed:
Hybrid, 7200 RPM
Interface:
SATA 6.0 Gb/s
Dimensions:
3.5" wide x .75" tall / 89 x 20mm
互換性
iMac G5 17" Model A1058
1.8 GHz (EMC No. 2055)
2 GHz
iMac G5 17" Model A1144
1.9 GHz
iMac G5 20" Model A1076
1.8 GHz
2 GHz
iMac G5 20" Model A1145
2.1 GHz
iMac Intel 17"
1.83 GHz (EMC No. 2104)
1.83 GHz (EMC No. 2110)
1.83 GHz (EMC No. 2124)
2 GHz
2.16 GHz
iMac Intel 20" EMC 2105 and 2118
2 GHz
2.16 GHz
2.33 GHz
iMac Intel 20" EMC 2133 and 2210
2 GHz (EMC No. 2133)
2.4 GHz (EMC No. 2133)
2.4 GHz (EMC No. 2210)
2.66 GHz (EMC No. 2210)
iMac Intel 20" EMC 2266
2.66 GHz
iMac Intel 21.5" EMC 2308
A1311 Late 2009 iMac10,1 3.06 GHz
A1311 Late 2009 iMac10,1 3.33 GHz
iMac Intel 21.5" EMC 2389
A1311 Mid 2010 iMac11,2 3.06 GHz
A1311 Mid 2010 iMac11,2 3.2 GHz
A1311 Mid 2010 iMac11,2 3.6 GHz
iMac Intel 24" EMC 2111
2.16 GHz
2.33 GHz
iMac Intel 24" EMC 2134 and 2211
2.4 GHz (EMC No. 2134)
2.8 GHz (EMC No. 2134)
2.8 GHz (EMC No. 2211)
3.06 GHz (EMC No. 2211)
iMac Intel 24" EMC 2267
2.66 GHz
2.93 GHz
3.06 GHz
iMac Intel 27" EMC 2309 & 2374
EMC 2309 Late 2009 iMac10,1 3.06 GHz
EMC 2309 Late 2009 iMac10,1 3.33 GHz
EMC 2374 Late 2009 iMac11,1 2.66 GHz
EMC 2374 Late 2009 iMac11,1 2.8 GHz
iMac Intel 27" EMC 2390
A1312 Mid 2010 iMac11,3 2.8 GHz
A1312 Mid 2010 iMac11,3 2.93 GHz
A1312 Mid 2010 iMac11,3 3.2 GHz
A1312 Mid 2010 iMac11,3 3.6 GHz
Power Mac G5
1.6 GHz
1.8 GHz (EMC No. 1969)
1.8 GHz (Late 2004)
1.8 GHz Dual (EMC No. 1969)
1.8 GHz Dual (EMC No. 1969C)
2.0 GHz Dual (EMC No. 1969)
2.0 GHz Dual (EMC No. 1969C)
2.0 GHz Dual (EMC No. 2023)
2.0 GHz Dual (EMC No. 2061)
2.3 GHz Dual (EMC No. 2023)
2.3 GHz Dual (EMC No. 2061)
2.5 GHz Dual (EMC No. 1969C)
2.5 GHz Quad
2.7 GHz Dual
13以上のデバイスを表示する
修理にまつわるストーリー
ユーザのアバター
問題
It needed a hard drive
修理
Very Well
アドバイス
Mark the plugs so you get them in right.
ユーザのアバター
問題
I got an email from Apple re: Seagate hard drive recall due to failure issues back in 2011 for their mid-2010 27" iMac models. I decided to ignore it because I was too busy and did not want to lug around the 27" iMac into an Apple Store. Well, flash forward to 2016, the hard drive finally crashed on . . .
ユーザのアバター
問題
When Apple recalled my late 2009 iMac because of hard drive issues, I was busy / procrastinating / lazy / traveling / etc. The computer still worked, and while everything I had was backed-up and in the cloud, I couldn't upgrade to Yosemite because it recognized the serial number of a recalled HD a . . .
ユーザのアバター
問題
My 24'' iMac hard drive went crazy and began a phase of advanced autodestruction.
修理
The guide is really precise and easy to follow. Some steps are a bit more technical, but the comments help with tips&tricks.
アドバイス
Don't hesitate to lever the front panel of the iMac (without pulling too hard on the camera wir . . .
ユーザのアバター
問題
Original hard drive died after a lengthily 7+ year stint in our house. I figured it would be cheaper to buy a new(and better hard drive) than buy a new computer so I went for it!
修理
Repair process was much easier than I expected. If you have a shred of fixit ability then this will be a piece of cake for . . .
ユーザのアバター
問題
My 27" iMac is five years old and the original 1 TB hard drive began to fail and needed to be replaced.
修理
The replacement took less than two hours. I was very surpised at how well it went. The IFixit free instructions and tools that I purchased from them were the best and I could not have done it wit . . .
ユーザのアバター
問題
Someone here was throwing away an iMac because the screen was broken. I picked it and found I could replace the screen for $89. I let the original owner know, but he said it was too old for him. So I ordered some additional memory and an Hybrid SSD 1 TB drive as well. Yeah! I am now windowless at ho . . .
ユーザのアバター
問題
HD went bad.
修理
followed the removal procedure and the repair went very smoothly. did not have to worry about numbers or anything like that. the ssd synced with the iMac sata bus speed perfectly at 3GB's.
アドバイス
very easy job. don't be afraid to attempt it.
ユーザのアバター
問題
Original Hard drive failed in my iMac EMC2134. Symptom: On boot up the machine chimed but then the drive made a clicking sound and Startup software couldn't be found, nor any of the startup services with option keys pressed! I was left with a grey screen and a flashing folder with a question mark in . . .
ユーザのアバター
問題
I suffered slow performance for 2 years and thought the machine was just getting long in the tooth. I created a Yosemite boot disk on a USB drive. The machine was incredibly fast when running even over USB 2.0, so I had a feeling it was the hard drive. I ran SpinRite for a day and it started to show . . .
さらに表示する
