必要な工具と部品
Slide the latch on the right to the unlocked position.
Slide the latch on the left to the unlocked position.
Remove the battery pack from the slot.
Working your way around the frame, unclip the mounting points of the frame surrounding the LCD screen.
Remove the two upper mounting screws securing the LCD to the lid.
Remove the two lower mounting screws.
Cover the keyboard with a cloth, then carefully lower the LCD screen onto the keyboard.
Using the plastic tab, peel back the tape securing the LCD cable the panel connector.
Unplug the connector.
The LCD screen can now be removed.
以下の翻訳者の皆さんにお礼を申し上げます:
100%
Jerry Wheelerさんは世界中で修理する私たちを助けてくれています! あなたも貢献してみませんか?
翻訳を始める ›
