必要な工具と部品
Slide the latch on the right to the unlocked position.
Slide the latch on the left to the unlocked position.
Remove the battery pack from the slot.
With your #0 Philips screwdriver remove the 2 screws from the bottom panel.
Now you can remove the bottom cover.
Lift out the plastic tab (including the rubber part that holds the HDD in its slot).
Slide the drive to the left to disengage the connector then lift to remove the HDD from its SATA3 port.
以下の翻訳者の皆さんにお礼を申し上げます:
100%
Jerry Wheelerさんは世界中で修理する私たちを助けてくれています! あなたも貢献してみませんか?
翻訳を始める ›
