はじめに
Replace the CMOS battery (maintains the BIOS settings needed to load your computer's operating system).
必要な工具と部品
Slide the latch on the right to the unlocked position.
Slide the latch on the left to the unlocked position.
Remove the battery pack from the slot.
With your #0 Philips screwdriver remove the 2 screws from the bottom panel.
Now you can remove the bottom cover.
Insert a plastic spudger in the left side of the battery holder and push the battery to the right to clear the tabs holding it in, then carefully pry the battery up from its holder.
Please recycle your batteries.
以下の翻訳者の皆さんにお礼を申し上げます:
100%
Jerry Wheelerさんは世界中で修理する私たちを助けてくれています! あなたも貢献してみませんか?
翻訳を始める ›
