メインコンテンツにスキップ
why! N240JU Replacing the LCD screen
必要な工具と部品
  1. why! N240JU Replacing the LCD screen, Battery: 手順 1、 2の画像 1 why! N240JU Replacing the LCD screen, Battery: 手順 1、 2の画像 2
    • Start by unlocking the right locking latch.
    • Then, by simultaneously unlocking the left latch, lift the battery out of its socket.
  2. why! N240JU Replacing the LCD screen, Access to main components: 手順 2、 2の画像 1 why! N240JU Replacing the LCD screen, Access to main components: 手順 2、 2の画像 2
    • Begin by spotting the dummy memory card.
    • Then, remove it and put it on your workplan.
  3. why! N240JU Replacing the LCD screen: 手順 3、 3の画像 1 why! N240JU Replacing the LCD screen: 手順 3、 3の画像 2 why! N240JU Replacing the LCD screen: 手順 3、 3の画像 3
    • Locate the 15 screws that hold the bottom cover of the device in place.
    • Unscrew them and place them on your work surface.
    • Then, un-clip the bottom cover, starting with the side shown in the third picture.
  4. why! N240JU Replacing the LCD screen, LCD screen: 手順 4、 3の画像 1 why! N240JU Replacing the LCD screen, LCD screen: 手順 4、 3の画像 2 why! N240JU Replacing the LCD screen, LCD screen: 手順 4、 3の画像 3
    • In order to remove the LCD screen, you must remove the connection cables from the Wi-Fi chipset.
    • Then locate the two connectors on the LCD screen.
    • Disconnect the first connector.
  5. why! N240JU Replacing the LCD screen: 手順 5、 3の画像 1 why! N240JU Replacing the LCD screen: 手順 5、 3の画像 2 why! N240JU Replacing the LCD screen: 手順 5、 3の画像 3
    • Peel off the tape from the second connector.
    • Then disconnect the second connector.
    • Locate the SSD M.2 drive.
  6. why! N240JU Replacing the LCD screen: 手順 6、 3の画像 1 why! N240JU Replacing the LCD screen: 手順 6、 3の画像 2 why! N240JU Replacing the LCD screen: 手順 6、 3の画像 3
    • Then dismount this disk because it must release the connection cables of the Wi-Fi chipset.
    • Free Wi-Fi connection cables now
    • Now locate the two screws that secure the screen to the rest of the Laptop (fan side)
  7. why! N240JU Replacing the LCD screen: 手順 7、 3の画像 1 why! N240JU Replacing the LCD screen: 手順 7、 3の画像 2 why! N240JU Replacing the LCD screen: 手順 7、 3の画像 3
    • Now locate the two screws that secure the screen to the rest of the Laptop (the other side).
    • Then lift the Laptop as shown in the second image of this step.
    • Unscrew the first screw.
  8. why! N240JU Replacing the LCD screen: 手順 8、 3の画像 1 why! N240JU Replacing the LCD screen: 手順 8、 3の画像 2 why! N240JU Replacing the LCD screen: 手順 8、 3の画像 3
    • Then unscrew the second screw.
    • Rest the Laptop as shown in the second image of this step and unscrew the third screw.
    • Then the fourth screw.
  9. why! N240JU Replacing the LCD screen: 手順 9、 3の画像 1 why! N240JU Replacing the LCD screen: 手順 9、 3の画像 2 why! N240JU Replacing the LCD screen: 手順 9、 3の画像 3
    • With the four screws unscrewed, separate the screen from the rest of the Laptop. Note that the hinge remains attached to the screen.
    • On the screen near the hinge now locate the two caches screws on the left.
    • Then look for those on the right.
  10. why! N240JU Replacing the LCD screen: 手順 10、 3の画像 1 why! N240JU Replacing the LCD screen: 手順 10、 3の画像 2 why! N240JU Replacing the LCD screen: 手順 10、 3の画像 3
    • Now remove the screw covers near the left hinge.
    • first on the right side of the hinge.
    • then on the left side.
  11. why! N240JU Replacing the LCD screen: 手順 11、 3の画像 1 why! N240JU Replacing the LCD screen: 手順 11、 3の画像 2 why! N240JU Replacing the LCD screen: 手順 11、 3の画像 3
    • Repeat near the right hinge
    • .Now return to the hinge on the left side and unscrew the outer screw.
  12. why! N240JU Replacing the LCD screen: 手順 12、 3の画像 1 why! N240JU Replacing the LCD screen: 手順 12、 3の画像 2 why! N240JU Replacing the LCD screen: 手順 12、 3の画像 3
    • Then unscrew the inner screw.
    • Repeat on the side of the right hinge.
  13. why! N240JU Replacing the LCD screen: 手順 13、 3の画像 1 why! N240JU Replacing the LCD screen: 手順 13、 3の画像 2 why! N240JU Replacing the LCD screen: 手順 13、 3の画像 3
    • You can now gently unclip the screen cover.
    • Locate the left hinge screw cover.
    • Locate the right hinge screw cover.
  14. why! N240JU Replacing the LCD screen: 手順 14、 3の画像 1 why! N240JU Replacing the LCD screen: 手順 14、 3の画像 2 why! N240JU Replacing the LCD screen: 手順 14、 3の画像 3
    • Gently remove the screw cover on the left hinge.
    • Also remove the screw cover on the right hinge.
    • Once the screw caps are removed you will see the fixing screws.
  15. why! N240JU Replacing the LCD screen: 手順 15、 3の画像 1 why! N240JU Replacing the LCD screen: 手順 15、 3の画像 2 why! N240JU Replacing the LCD screen: 手順 15、 3の画像 3
    • Now unscrew the screw on the left hinge.
    • Then unscrew the screw on the right hinge.
    • Once this is done you can now remove the hinge cover (left).
  16. why! N240JU Replacing the LCD screen: 手順 16、 3の画像 1 why! N240JU Replacing the LCD screen: 手順 16、 3の画像 2 why! N240JU Replacing the LCD screen: 手順 16、 3の画像 3
    • Left hinged cover removed.
    • Then remove the cover from the right hinge.
    • Right hinge cover removed.
  17. why! N240JU Replacing the LCD screen: 手順 17、 3の画像 1 why! N240JU Replacing the LCD screen: 手順 17、 3の画像 2 why! N240JU Replacing the LCD screen: 手順 17、 3の画像 3
    • once these operations are done you see the LCD screen ready to be dismounted.
    • Now locate the screws that secure the LCD screen to the bracket and unscrew them. Two on the left.
    • Two on the right.
  18. why! N240JU Replacing the LCD screen: 手順 18、 3の画像 1 why! N240JU Replacing the LCD screen: 手順 18、 3の画像 2 why! N240JU Replacing the LCD screen: 手順 18、 3の画像 3
    • Once the screws are unscrewed, lift the LCD screen gently and flip it over.
    • You will then see the connection cable of the screen.
    • Locate its connector.
  19. why! N240JU Replacing the LCD screen: 手順 19、 2の画像 1 why! N240JU Replacing the LCD screen: 手順 19、 2の画像 2
    • Disconnect the cable.
    • And here you can now put it on your work plan.
終わりに
To reassemble your device, Follow these instructions in reverse order.
ある他の人がこのガイドを完成しました。
以下の翻訳者の皆さんにお礼を申し上げます:
fr en
100%
irlandaさんは世界中で修理する私たちを助けてくれています! あなたも貢献してみませんか?
翻訳を始める ›
作成者
1人の作成者と共同作成されました。
Felice Suglia
メンバー登録日: 06/15/13
33,538 ポイント
283のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 5
今までの合計 551
