必要な工具と部品
Start by unlocking the right locking latch.
Then, by simultaneously unlocking the left latch, lift the battery out of its socket.
Unscrew the circled screws in green and red
Put the computer in the position of the second image while pushing a paper clip into the hole of the screw circled in green until you hear a click
Lift the keyboard
Begin by spotting the dummy memory card.
Then, remove it and put it on your workplan.
Unscrew the screw circled in red
Pull out the M.2 SSD in the direction of the red arrows
Remove the screw circled in red
Lift up the hard drive
Remove the hard drive in the direction of the red arrows
Disconnect the two connectors marked in green
Remove the WLAN card
Press with a screwdriver in the red circled area to spread the base of the battery
Remove the battery by holding the screwdriver down
Lift the retaining flap off of the connector boxed in red.
Disconnect the connector boxed in red.
ある他の人がこのガイドを完成しました。
以下の翻訳者の皆さんにお礼を申し上げます:
100%
これらの翻訳者の方々は世界を修理する私たちのサポートをしてくれています。 あなたも貢献してみませんか?
翻訳を始める ›
