メインコンテンツにスキップ
注意:あなたは必要条件ガイドを編集しています。あなたが行なう変更は、この手順を含む全ての20個のガイドに反映されます。
英語
フランス語
手順 3を翻訳中
手順3
Before you can yank the upper case off, you must disconnect the trackpad connector, the blue and white power cable, and speaker cable as described in the next steps. Be especially careful with these cables; never pull directly on the cables, but use a spudger to pry up the connector directly.
  • Before you can yank the upper case off, you must disconnect the trackpad connector, the blue and white power cable, and speaker cable as described in the next steps. Be especially careful with these cables; never pull directly on the cables, but use a spudger to pry up the connector directly.
  • Lift the upper case and use a spudger or your finger to disconnect the trackpad connector hidden beneath the white plastic tab. Due to model variatons your trackpad connector may be different than the one pictured.
ここに翻訳を挿入する
ここに翻訳を挿入する
クリエイティブコモンズのオープンソース著作権のもと、あなたの投稿は著作権の対象となります
