メインコンテンツにスキップ
修理を始めるには
修理する権利
パーツ&ツール
注意:あなたは必要条件ガイドを編集しています。あなたが行なう変更は、この手順を含む全ての2個のガイドに反映されます。
英語
フランス語
手順 19を翻訳中
手順19
Check the glass directly in front of the webcam for dust and other contaminants. If necessary, wipe it down with a microfiber cloth before you seal up the display. Steady the display with one hand as you remove the adhesive liners in the following steps, or rest it lightly against the iMac's enclosure. Steady the display with one hand as you remove the adhesive liners in the following steps, or rest it lightly against the iMac's enclosure.
  • Check the glass directly in front of the webcam for dust and other contaminants. If necessary, wipe it down with a microfiber cloth before you seal up the display.
  • Steady the display with one hand as you remove the adhesive liners in the following steps, or rest it lightly against the iMac's enclosure.
Avant de sceller l'écran en place, vous voudrez peut-être tester la mise sous tension de votre iMac pour vous assurer d' avoir tout reconnecté correctement. Faites attention à ne pas toucher quoi que ce soit à l'intérieur pendant que la machine est sous tension.
Tout en appuyant l'écran contre son rebord sur le panneau frontal inférieur, abaissez-le en place.
[* icon_caution] Before sealingicon_reminder] Check the screenglass directly in place, you may want to test powering on your iMac to ensurefront of the webcam for dust and other contaminants. If necessary, wipe it down with a microfiber cloth before you reconnected everything correctly. Be careful not to touch anything inside whileseal up the machine is powered ondisplay.
[* black] While pressingSteady the display against its ledge onwith one hand as you remove the lower bezel, loweradhesive liners in the following steps, or rest it down into placelightly against the iMac's enclosure.
クリエイティブコモンズのオープンソース著作権のもと、あなたの投稿は著作権の対象となります
