メインコンテンツにスキップ
注意:あなたは必要条件ガイドを編集しています。あなたが行なう変更は、この手順を含む全ての3個のガイドに反映されます。
英語
フランス語
手順 5を翻訳中
手順5
Lift the home button bracket starting from the left side. Carefully pull it upwards toward the display, making sure not to damage the home button cable. During reassembly, after installing the home button, you'll need to glue this bracket into place to secure it.
  • Lift the home button bracket starting from the left side.
  • Carefully pull it upwards toward the display, making sure not to damage the home button cable.
  • During reassembly, after installing the home button, you'll need to glue this bracket into place to secure it.
  • Scrape off as much of the old adhesive residue as you can, then clean it with acetone or high-concentration (90% or greater) isopropyl alcohol.
  • Secure the bracket with a high bond glue, superglue, or high-strength double-sided tape. Make sure the bracket is aligned correctly before allowing your adhesive to cure, or the home button will not click when pressed.
  • It may be necessary to use vise clamps to hold the home button bracket in place as the adhesive cures.
ここに翻訳を挿入する
ここに翻訳を挿入する
ここに翻訳を挿入する
ここに翻訳を挿入する
ここに翻訳を挿入する
ここに翻訳を挿入する
クリエイティブコモンズのオープンソース著作権のもと、あなたの投稿は著作権の対象となります
