はじめに
This guide shows how to remove and replace an inner tube of a tire. This process may difficult he first time it is attempted.
必要な工具と部品
Remove the flat tire by loosening and removing the axle nut with a 19 mm wrench.
Unscrew the axle bolt with a 19 mm socket wrench.
Remove the axle bolt from hole and remove the wheel from the wheelchair.
もう少しです!
終わりに
ある他の人がこのガイドを完成しました。
