はじめに
This bike-to-bike intercom system was given to me by a friend for repair. He is an avid bike rider and purchased this set a while ago but did not have time to ever use it. Once he did try to charge it it would not take a charge. I assumed that it was the batteries since they have never been charged. They may have been depleted below the threshold of where they would accept a charge. When he called the cardo support number he was told that "There is no out of warranty service for scala rider batteries." He would need to purchase a new scala rider headset in this case. Really? Lets check this myth about the "not user serviceable" battery.
必要な工具と部品
scala rider Q2 bike-to-bike intercom. Retail price $379.99 and never used.
Individual unit with carrying pouch
Back of the bluetooth intercom device
Insert a small guitar pick or similar tool to separate the individual halves. Start by the charging port end since this seems to be a better entry and not quite as tight.
Continue to use the pick left and right of the charging port. As the pick advances, one can feel the separation of the adhesive.
Multiple passes along the sides of the halves will be necesarry
Both screws are the same length.
Lift the logic board gently of the case. Do not try to totally remove the board. There will be four wires that attach the board to the case as well as the battery cables.
With the board lifted remove the battery from the case. It is adhered with double sided tape and comes of relatively easy
10 の人々がこのガイドを完成させました。
